Solid State Orbo System
futuristic
Just brainstorming... If cylindrical magnetised magnets are hard to find, maybe we could use regular ;)
Groundloop
Bruce,
I got my new hexfets today so I will repair my switch. But I will not get the ordered
copper wire and other stuff until next weekend. So I will not be able to build any new
generator setup until then. It seem that the sky is the limit but we need only 1 Watt
continuous output to prove that the system works. So I will build my resonant oscillator
circuit and try that out, but with one coil only since I do not have any more wire.
Alex.
Groundloop
@futuristic,
Good idea.
Yes that will work. But I think it will be easier just to stick one
magnet at each toroid end. We need just a little field to get
the generator output going. So if we use your center core idea
and then stick a magnet at each end, then it will be perfect.
Alex.
Bruce_TPU
Quote from: Groundloop on January 08, 2010, 07:57:33 AM
Bruce,
Alex.
Hi Alex,
I could help you with buying the wire, gladly!
What is the frequency of the electrical power on your one output coil, with your present set up?
We can test my generator efficiency increase on this set up.  But first I need the frequency.
Cheers,
Bruce
Groundloop
Bruce,
Thanks for the offer. But I have already ordered more wire.
The frequency of my RA switch is from approx. 1KHz and up to 19KHz with
the component values the switch has now. But as I said, I will build the
resonant oscillator and test what the resonant frequency for the coils are.
Will report back later when done.
Alex.
