Solid State Orbo System
Started by Groundloop, January 06, 2010, 12:21:24 PM
Groundloop
Luc,
I have read about the Flynn Parallel Path but not in detail.
I did build the Tom Beardens MEG and that one did not yield
any over unity. The first I'm going to test is the double path
solid state I posted earlier. If this test turns out bad then I see
no problem reconfiguring the setup to try out your idea.
Alex.
gotoluc
Thanks for the quick reply Alex,
Do you have a image of that one? what post number is it?
Luc
Groundloop
Luc,
Never posted my MEG here. Attached is a image of the unit.
The double path solid stater is on page 1 of this thread.
Alex.
Bruce_TPU
Hi Alex,
Here is a "fun" thought experiment.  Any thoughts?   :)
Cheers,
Bruce
Groundloop
Bruce,
The Neo magnet in the Metglass core is so strong that if I try to
remove it then I will rip the core apart. The Metgalss core is
tape wound and extremely brittle. But you have a good idea.
Alex.
