Solid State Orbo System
Started by Groundloop, January 06, 2010, 12:21:24 PM
Bruce_TPU
Hello ALL,
These next numbers are even more strange!  LOL
Top coil of the middle stack of 4:  By itself:
.775        V
70.8        R
0.01095    I
0.00849    P
NOW< Watch what happens when it is added in Parallel with the two directly below it.
2.105        V
45.5          R
0.04626     I
.09737       P
67.22% increase in wattage (power) because of this one coil!
Cheers,
Bruce
rave154
Bruce,
great work so far  :)
could you state what your input voltage and current draw is alongside your outputs so as to enable a comparison to be made? also frequency/s and duty cycles.
oh, just remembered, what exactly is the difference between a Brooks coil....and a standard-dandard coil? ( id never heard of a Brooks coil till you mentioned it )
keep up the great experiments
Bruce_TPU
Quote from: rave154 on March 02, 2010, 02:10:53 AM
Bruce,
Hi Rave,
A Brooks Coil:   ;D Fun link!  Google brooks coil if you want more, but it says it all IMHO!!! http://crackedforge.wordpress.com/2008/09/03/superconducting-magnetic-energy-storage-rocket/
With an added turbo boost of a dc bias to strengthen the B field.  "Shields are up Captain!"  Bias acts like a force field, holding everthing inside, in very simple terms.
Off to bed, more fun tomorrow....
Cheers,
Bruce
Groundloop
Bruce,
Yes, you are correct. I did use a 555 oscillator circuit that did control a mosfet.
The circuit had variable resistors for frequency, duty cycle and mosfet gate resistor control.
I did try out all the frequencies the circuit could handle. At no point was the output
greater than the consumed input power. I did find that the output was high
voltage "radio wave like" and did disturb my digital volt meter a lot. I also found that
the circuit did alter the tuning when I brought my hand closer to the coils.
@rave154
A Brooks Coil is generally known as a special case of the circular coil inductor of rectangular cross section that is implemented to achieve the maximum inductance with a given length of wire.
http://www.nessengr.com/techdata/brooks/brooks.html
Alex.
gravityblock
Quote from: Groundloop on March 02, 2010, 02:39:43 AM
Bruce,
Alex.
How was your circuit changing the capacitance twice per period of oscillations in order to achieve parametric resonance?  How was your pickup coil resonating at twice the frequency as the toroidal coil in your circuit?
Did you try a varicap diode?  Parametric resonance is different from regular resonance.  Your circuit did not change the capacitance twice per oscillation.  The parameters must vary at roughly twice the natural frequency of the oscillator.  Your previous circuit does not achieve parametric resonance.  I hope you will modify your circuit in order to achieve parametric resonance, because I would fail miserably in trying to design a circuit.
Thanks,
GB
