Solid State Orbo System
Started by Groundloop, January 06, 2010, 12:21:24 PM
Bruce_TPU
Hi Gyula,
Wow, you are good at that Calculus!  What a great amount of information.
I am going to redo that experiment tonight with the resistor because, my voltage is now at 30 volts pretty steady on the output.
I will redo it, and let you know what the voltage is across the resistor.
Also, I have no inductance meter, but purchased one last night, so I will be able to take an accurate reading when it arrives and see how close our math is.
Thank you very much for your time and I will get back with you this evening.
Cheers,
Bruce
http://www.energyfreedomreport.com
lumen
Quote from: exnihiloest on March 08, 2010, 05:16:20 AM
During the magnetization, energy is stored for a part in the magnetic field of the coil and as internal energy for saturation. A voltage is induced in the pickup coil by the leakage flux (see the oscilloscope trace). There is a leakage flux because the permeability is not uniform along the toroid.
During demagnetization, the leakage flux, which is not small, induces voltage in the pickup coil and current in the load.
If the principle was not a leakage flux but permeability modulation, then the toroid plane could be put parallel to the pickup coil plane. But this configuration doesn't work, as well as your thesis.
@exnihiloest
A normally machine wound toroid coil will produce a flux in the parallel plane because the layering of windings are the same as loops of wire in the parallel plane.
synchro1
@Bruce, MCE stands for Magnetic Caloric Effect. It is a Magneto thermodynamic phenomenon which is a reversable change in temperature of a suitable material caused by exposing the material to a changing magnetic field. Materials heat when magnetized and cool when demagnetized. Consult the following link at Wikipedia for a further elaboration.http://en.wikipedia.org/wiki/Magnetic_refrigeration
Zaev reports generating cold and electricity in his experiments with his mag and demag of dielectrics. Think about whats going on. You're accumulating heat loss, and generating electricity simultaneously. The heat loss is greater then 1., the cooling should equal the heating, but it doesn't! It accrues instead!
exnihiloest
Quote from: gravityblock on March 08, 2010, 05:26:48 AM
Why does this cooling effect bother you?
You said:
"A few others here have also reported a cooling effect from their replications."
If it is not related to Orbo, I suggest you speak elsewhere about the Amdam's motor. It is not the goal of this thread. Thanks.
exnihiloest
Quote from: lumen on March 08, 2010, 09:37:15 AM
@exnihiloest
Right but only one turn/layer should not provide much flux (the 2Sgen pickup coil doesn't recovers energy when it is in the same plane as the toroid).
