Solid State Orbo System
Started by Groundloop, January 06, 2010, 12:21:24 PM
Groundloop
@Freezer,
You never got back to me on the PM so I decided to post the
circuit you asked for here. This circuit needs about 110 volt
input to work. The resistor value sets the trigger voltage.
If you use a lower resistor value the trigger will happen at
a lower input volt. I have not tested this circuit but I see no
reason it will not work as designed. You MUST use the TIC106
SCR because other SCRs have a too high trigger current.
Groundloop.
synchro1
Quote from: Energy4All on April 12, 2010, 05:41:07 PM
Hello Synchro1. I would start with the A frequency and work your way up on an experimental basis. If you run into a particularly strong magnetic frequency there I can only theorize that the device will pull your two permanent magnets into your output core and or allow for such an inrush of magnetic potential that it could result in a brief; but large current increase in the device. In theory what I am trying to get you to see is that you could tap the earth magnetic field if you view the device as a magnetic pump directly coupled with the earth magnetic field. This is just theory; but does pose questions and as yet unknown factors.
Absolutely, the work of Tesla's first patent for the spark gap generator! The problem is it's hard to fit the ground mechanism aboard a flying saucer. One can get demagnetization over unity from running pulsed D.C. backwards through an ordinary 120 volt to 3 volt AC to DC transformer. Lidmotor has several good videos where he stores the backwards transformer feedback into a cap and runs a pulse motor with the generated power.
Energy4All
Hello Syncro1 I am familiar with Lidmotors work. I subscribe to his chanel. On that note transceivers such as those Dr. Stiffler employs in his SEC technology are probablt all you will need to feed the system. Tesla transceivers with the copper ball on top will work fine.
synchro1
Here's a picture of a racetrack Nanoperm core and a Hyperlink to the distributor. The all or none switch characteristic of magnetic flux, and the tiny amount of additional reluctance needed to prejudice the path of least reluctance exclusively to one or the other race track paths, makes the minimal aperture wrap very efficient. This race track nanoperm core looks enticingly similar to Colonel Beardens costly and cumbersome Honeywell core. Just think of the input savings with a microscopic flux blocker wrap over Beardens design!
http://www.powermagnetics.co.uk/nanoperm.html
Energy4All
Hello Groundloop. You asked what would happen if you came in contact with the device. The aswer is nothing good. Similar to the Mark Stevens Device contact. Directly related to employing the Earth Magnetic Field; doing so left Hendershot paralyzed and in a wheel chair. For a real world example go to http://www.scribd.com and search for and download and read "The Hendershot Mystery". He directly coupled with the earth EMF and employed it as I am describing the possibility.
