Perendev?
Started by beedees, March 16, 2006, 03:19:26 PM
Omnibus
Stefan, Mike Brady assured me in an e-mail message the other day that his motor is completely self-sustaing. To verify a self-sustaining motor you don't need to carry out measurements. If it really is it's the easiest thing in the world to prove irs validity.
WalMartGreeter
Quote from: Omnibus on March 24, 2006, 11:23:00 PM
Get real. They will be out of their minds to set up this show and not demonstrate a self-sustaining device. Faking self-sustaining device is impossible, it requires no measurements and its viability is evident without approval from self-proclaimed authorities. Fakes (either due to incompetence or deliberate) can only happen when measurements are involved.
That's why they've announced this EM design.  A working permanent magnet device would simply run by itself and there'd be no doubt.  But a purely permanent magnet design can't possibly work (and I think they know that), and it wouldn't allow any fakery to make it appear to work.  Remember, this is all about wowing potential investors.
IF (and that's a big IF) they demonstrate a "self-sustaining" device, it will be a battery-powered device using electromagnets, and not a purely permanent magnet device.
They will do the same thing Tilley did with the TEV and Brits and Christie did with the Lutec: they will run it on the batteries for a short period of time and measure the unloaded battery voltage before and after the run.  When the voltage after the run is higher than before, they will claim that the device actually charges the battery as it runs.  (Read a bit about batteries to see why the voltage can increase.)  And this will be good enough proof for a lot of people in the audience.
But they will not run the device without the batteries, nor will they remove the batteries from the circuit once the device is started.  They may claim it's self-sustaining, but it'll really be the batteries powering it.
I assure you, with 100% confidence, they will not demonstrate a self-sustaining device.
Smith001
How could anyone be skeptical about the new Perendev motor when they've provided a beautiful 200x200 pixel CAD drawing as proof !!
Omnibus
QuoteBut they will not run the device without the batteries, nor will they remove the batteries from the circuit once the device is started.  They may claim it's self-sustaining, but it'll really be the batteries powering it.
Why should I believe you? Tell me one reason I should believe you?
This is a completely unjustified attack. I?m not an advocate of Brady but I resent such unbecoming, frivolous talk.
I repeat, demonstrating of a self-sustaining device, if real, is the easiest thing in the world. They will be out of their minds to set up such show with such claims and not demonstrate a truly self-sustaining device.
Omnibus
QuoteRemember, this is all about wowing potential investors.
Why are you so much concerned about other people's money?
