The Rife Machine
Started by Foggy-Notion, January 07, 2010, 02:44:43 AM
smallhagrid
I have found ample info about using a PC as the frequency generator and have already downloaded the programs and scripts - but the rest is very elusive.
There is some mention of simply using sound - but that it does not penetrate; some mention of using an audio amplifier, but how to get the signal into the gut is not there; also there is mention of using a plasma ball, which seems kind of wild to me.
Another poster here mentioned using the sound card output of a PC with a reversed transformer - and that is as far as it went.
Electrical connections to a person's body are problematic at best.
There's all sorts of theories and controversy.
Some say make 'em with sponges - others say copper tubes with wet paper towels - and others still scream 'NO COPPER, EVARRR !' - and then some say SS is OK, and so on - ad nauseum.
I would love to see some clear info about the exact how-to of doing the Rife PC thing inexpensively ?!
Here is info from a very old posting I found on the www:
Some of you have heard of the Rife Machine haven’t you?
If not, you should know that a man named Dr. Rife, the inventor of the most powerful microscope, discovered that virus’s and parasites could be ‘shattered’ by a specific frequency. Just as a great opera singer can ‘shatter’ a specific glass with a specific frequency.
Dr. Rife performed countless experiments, and actually cured many people using a frequency generating machine. He eventually discovered the specific ‘shattering’ frequencies for thousands of virus’s and parasites.
Unfortunately, Dr. Rife’s work has been suppressed since the 1930’s.
But now, at last, his work is beginning to again raise interest.
Lately, a few intelligent people have created computer programs that send out the “Rife Frequencies” right through the sound card of your computer.
The problem is that sound does not travel very well through the body. Although I believe that just listening to the sounds will help a condition, if you can get the sounds/frequencies deeper into the body, then you will get the most benefits.
Some have attached electrodes directly to the positive and negative outputs of One channel of the soundcard. Then just hold the electrodes to the skin, or hold one in each hand.
But the electrode method introduces a small voltage into the body, and may be dangerous to some individuals. I have personally tried this method, and I am still alive and well. It did seem to work. I only had the opportunity to test it on colds and flu, but I will say that it seemed to shorten the recovery time substantially.
Recently, a discovery was made that will enable the Rife frequencies to penetrate deeper into the body using just the sounds… with a little help.
And here is how to do it for $50.00 or less.
1 â€" Download the FREE Rife Frequency Generator Programs.
(Missing info, sorry.)
(this one is called Frex, Look for a filed called Frex16-061103.exe and download it)
Instructions: Open program, choose ailment, then press ‘Start’. This will open another window, switch the ‘Run’ button to Run.
(this one is called Freqgen â€" Look for file Freqgen113.exe and download it)
Instructions: Open program, choose ailment, press ‘Open’.
It would be better if you hooked your computer up to a good stereo system, as your computer speakers are not powerful enough, and do not have the proper frequency range.
Now here’s the kicker.
You will need a Plasma Ball, yes a plasma ball. The kind you have seen everywhere in novelty shops. (You see the electric plasma moving inside the ball, and when you touch it the plasma moves to your fingertips.)
Well, as it turns out, this ball releases electromagnetic radiation that penetrates the body.
So, you will need a ‘sound activated’ plasma ball. These are sold everywhere.
The bigger the ball, the better. Look for 7” or bigger.
Some balls have a microphone inside, and some have a stereo input. A stereo input will drive the ball harder, but then you will not hear the actual sounds through your stereo.
A better, safer, and easier way is to just hook up your stereo to the computer and place the microphone version of the plasma ball right next to the speaker.
In this way, the ball will pick up the Rife frequencies from the stereo speaker and re-transmit the electromagnetic frequencies to you.
Some precautions are: Not to go too near to the ball when trying a new frequency set. Wait until you can gauge your body’s reaction. Even then, you only need to be within 6 feet of the ball for penetration.
Expect die off and healing crisis.
Here is a link for “Sound Activated Plasma Balls”:
http://www.google.com/search?client=firefox-a&rls=org.mozilla%3Aen-US%3Aofficial&channel=s&hl=en&q=sound+activated+plasma+ball&btnG=Google+Search
Any additions here ?
papazaf
i have tried the sound card plasma ball system with the Frex16 program,
but i don't know , what kind of wave form to use to drive the ball?
Should the plasma ball have constant stable sparks or the sparks must tremble as the sound ?
angryScientist
I stayed with a guy for a while when I was younger and he had a couple of original Rife machines. There was a transmitter and a transceiver as I recall. A couple of pieces where missing I was told. The magnetic coils where there but the electrical globes were missing. I was told that they looked like regular large light bulbs but where filled with a noble gas so they glowed blue or something.
The thing I found most fascinating was on the transceiver. There was a glass plate build into "desk top" of the unit right next to the recessed specimen dish. What one was supposed to do was either plug in the magnetic devices or electric devices or put a sample in the specimen dish and tune through the frequencies using the array of nobs on the face of this desk like unit. While running through the frequencies the operator would gently rub his finger on the glass plate. When the right frequency was reached the finger would "stick" to the plate more than at other frequencies. The operator would then note the frequency and use it with the smaller transmitter to do the treatments.
Fascinating units. I thought about opening the units to see what was inside but they were sealed, the electrical circuitry any way, in a regular metal box and I did not want to break the solder joints. So I left them in their original condition.
It appeared that they where simple tube type oscillators.
I don't know what happened to the units. I'm not even sure who exactly owned them. Whether they belonged to the guy I was staying with or the owner of the shop that we were staying in. The guy I was staying with ran off with his friends wife and moved to a town just over the mountain range, about fifty miles from here, as the crow flies. The owner of the shop still lives here in town and was on the volunteer fire department with me but has since retired.
Like I said I don't know what happened to the units but I still thought it was fascinating that that type of technology and bit of history could be found in this small town that I live in.
szaxx
Hi All,
Don't forget the original system had a 'gas chamber' the size of a large room. This was also fitted with coils at the base where the healing powers were most effective.
A smaller unit following this approach requires a gas chamber of sorts too. The plasma ball is a readily available device and 'sending' the modulating frequencies into this seems to be a large problem when I read info from many sites.
Understanding the operation of a amplitude modulator as in AM transmitters will solve this somewhat. A transformer type system applied may have a limited frequency range but can be used successfully over a host of other suggested methods. The main problem you will encounter with this system is the transformer may have to be home brewed as it requires a very high voltage insulated construction between the coils within. Large pot cores may suffice here but search for one suitable for use at audio frequencies. This can be fed via an amplifier from a PC and will function as required.
Beware of the isolation in the transformer, if insufficient construction here or insulation is ignored you may have a poorly PC which the rife cannot cure lol.
As far as the waveform to use, sinewave is the purest as they contain no harmonics. The square wave for example is a mass of different frequencis all harmonically related so what is suggested by your ailment will be full of unwanted frequencies. This may produce negative effects.
As this technology is in its infancy there needs to be as pure a signal as possible. The level of signal and the exposure times are still an unknown at present as the energy from the device has no known units of quantity, and the measuring device required for this also at present is unavailable to my knowledge.
Happy hunting and hope this helps.
Steve.
arhitrade
