Our black pope and his jesuits, a look at mankind's enemy...
Started by Gauss, January 08, 2010, 02:59:52 AM
Gauss
One more thing. In case you are a virtuous person doing FG and researching FE, you will have protection against dark forces. In case someone wants to kill you they are not allowed to do that at will without paying a hefty price. BUT if you do a mistake for own gains, down you go. Open source, the name of the game.
jikwan
well, gauss, thankyou for your optomism and bright energy.
for 20 years+ i was just like you....
raving about the great systems of india and far east
you got to read this or do that to anyone that might listen
sincerely trying to help with their karmic blocks etc
its exhausting work--encouraging others to change their karmas
when it works then ones store of merit goes up
when it dont (usually the case) your time and energy is wasted
what has developed over the past few years is ive tried some thing new....
and it results in freedom, peace and absence of conflict
and people like you all the more for it.......
leave people alone....do not oppose their views...dont try to change them
let them be exactly as they are
so far this has been working very well
of course, if i find anyone really interested in change-we can discuss
i wish i had realized this decades ago
your mention of protection against dark forces is very interesting
and my thoughts about it is theory/logic/extrapolation
if a "spiritual terrorist" or someone seriously active against evil forces
is making a success of it-then it should be possible to track them down
by using subconscious mind...pendelum/divining rods/astral travel/the
help of clairvoyants etc
the subconscious mind is said to know everything
not different from the mind of the buddha
if you dont have buddhas mind then youll have to use the above mentioned devices
regarding overunity or anywhere near it
theres a great long list of OU giants been killed/disappeared/imprisoned/suppressed
shauberger, tesla, many watercar and electrical geniuses have fallen
i do believe big oil/jesuits/masons etc would pay the hefty price to get rid
of serious opposition because billions $$ would be lost
i worry about myself sometimes
what i hope to do as soon as conditions are favourable
i have a design for 100% hydrogen powered do it yourself engine
its practically guaranteed to work
heres the recipy
vaccuum electrolysis (no bubbler)
80+plate dry cell
additional fitted generator
ssteel valves/exhaustpipe
nickle plated head/piston top and upper ring
topmost part of cylinder sleves ssteel
an aussie guy ran his 6 litre car using vac electrolysis
about 15 years ago
using wet cells
not too much problem
i dare say any schoolboy with a bit of mechanical compedence
can do the same
my model has 2 differences
using ultra low water-level drycell
nickle-plating/ss all corrodables
zen is the art of seeing everything and noticing nothing
sparks
  It has always fascinated me as to how randomized acceleration and collision of molecules can be converted into a more ordered form of energy. If as a liquid boils due to thermal agitation the molecules that boil respond to a highvoltage field they now align their electrical dipole moments with the impressed electrostatic field.  The energy gained from the boiling liquid is then able to be focused electrically.  As the accelerated gas leaves the liquid it is now caused to focus into a very narrow stream of molecules.  These accelerated neutral molecules are then caused to collide upon a metal emitter with enough velcoity to raise the temperature of the target metal way above that of the input temperature.  The atoms loose velocity and fall back to the bulk liquid. The vaporization of the water in this case can occur at well below the thermal background temperature due to the partial pressure of the evacuated vessel.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
jikwan
sparks, it looks to me this is a ko-an
i guess it might be a suggestion how to separate the water
FROM hydrogen gas on its way to the combustion chamber
sparks
Its more like a heat pump but instead of using a compressor which fights the thermal agitation of the gas to raise its temperature it electrostatically focuses the molecules accelerated from the surface of the liquid onto a collector.  The collector metals temperature is now caused to rise above the ambient temperature into usable levels.  There is no thermodynamic laws broken here.  The heat travels into the bulk liquid.  Causes the molecules to leave the surface of the liquid where there acceleration is guided to a metal target.  The metal target is heated by the focused gas molecules colliding with it.  The metal then allows for the heat to flow into the desired distribution process.  Your idea of operating a cell at below atmospheric pressures is what got me thinking about this.  There are other gases which could be used that respond to a magnetic field.  Again this is just a collection scheme but it would operate at below ambient thermal conditions enabling a flow of heat energy into the system and out at a higher temperature.
Think Legacy
Spread the Love
