Possible experiments with HV Plasma
Started by Judges, January 07, 2010, 07:02:16 PM
Judges
Good Grief,Charlie Brown,,,
Not Fusion=off
PLASMA=on hold,,
WAY to many projects!
Joe.
sparks
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
Judges
http://cr4.globalspec.com/thread/49714/Mu-Metal-Faraday-Cage
Interesting thread,,that,,,and do you see the similarities with this Forum?
Indeed
THAT (as Martha Stewart would say) is a "good thing"
I have replied there as a Guest as I am sure some of you have.
The problem is not with this or that forum but instead the sharing.Thank you for allowing me here.
I see other threads like mine,filled with ideas.Perhaps this, some day,will mesh with a newer idea.
My High Voltage brute strength PLASMA,thread,,has turned into the evolution of the material to make my ferro fluid.
KEEP um Comeing
Joe in Texas
sparks
    I cant imagine the outcome of a cavitation within the field of a plasma.  The free electrons would most likely drift into the cavity depending on the magnetic field lines permeating the plasma field.  Then the bubble shrinks at a very accelerated rate.  Often approaching the speed of light.  The electrons have no choice but go for an inward towards each other ride.  They create a very negative pole and sure as hell are gonna fly away as fast as they can out of the plasma.  I forget how fast an electron has to go before it starts doing a little blue shifting.
Think Legacy
Spread the Love
jadaro2600
What if you constructed two individual positive electrodes with common negative ground and alternating when one was on the other isn't , then formed them in such a way as to create cavitation between them in the space between, ..bumps, or what have you.
