"Tiny Orbo Replication" over 100% efficiency
Started by PaulLowrance, January 27, 2010, 12:17:55 PM
PaulLowrance
I received my Enermax Marathon PC fan that according to the ebay ad is supposed to be "friction-free" due to magnets.  What a waste of $8!  -->
http://globalfreeenergy.info/2010/02/01/enermax-marathon-pc-fan/
jadaro2600
Quote from: PaulLowrance on February 01, 2010, 01:07:40 PM
haha, a friction free fan wouldn't cause air to move.
I think that it would be a good idea to post some images of your setup rather than your circuit diagrams - this may help replicators a little.
Bruce_TPU
Hey Paul, I wonder if your latest circuit would work driving my four toroids in series?  Any thoughts?
Thanks,
Bruce
http://energyfreedomreport.com
PaulLowrance
Quote from: jadaro2600 on February 01, 2010, 10:57:56 PM
Actually they claimed friction-free *bearings*. What a joke. More like massive friction bearings.
Quote from: jadaro2600 on February 01, 2010, 10:57:56 PMI think that it would be a good idea to post some images of your setup rather than your circuit diagrams - this may help replicators a little.
How about 3 youtube videos since Jan. 16, 2010?  ;)
World's Tiniest Steorn "Orbo replication", January 16, 2010
http://www.youtube.com/watch?v=c6erWHYSHSs
World's Tiniest Steorn "Orbo replication" - Flat current pulse, January 17, 2010
http://www.youtube.com/watch?v=u10do21JLAQ
Today's work on "Tiny Orbo Replication 2", January 27, 2010
http://www.youtube.com/watch?v=8Z-AhflaoVA
PaulLowrance
Quote from: Bruce_TPU on February 02, 2010, 12:57:37 AM
Thanks,
Bruce
It depends on total inductance of all four toroids when they are well into the saturation curve, and your machines rpm. The circuit takes the energy put into the toroid and uses it sustain the current pulse as the magnet moves away. Well, at least it supposed to maintain the current. According to LTspice I should expect ~ 10% decay in current at 15,000 rpm with one toroid, and possibly less decay with two toroids. The circuit is for high rpm designs. I know, Sean says the current needs to be constant, but I don't buy that. Well see about that with my new design.  :)
