Building DS Plasma Globe
Started by h2ocommuter, January 29, 2010, 02:49:18 PM
h2ocommuter
One of my friends found this today when I was looking for the Eric Dollard video for him
This is way more than I had ever imagined. http://www.youtube.com/watch?v=f5ZWrjcrPl4&NR=1
Enjoy. Get out your notebook to take notes when watching.
Get this out to others in your world.
Working together we can achieve what we set out to do.
Blessings and good will to all.
Zane
h2ocommuter
Video acknowledgements and plasma globe associations.
Recent mentoring notes sent to me,
"Remember that don smiths devices are extremely difficult to understand, you need to be a radio freq. expert."
Gulp!
Then I found the videos... serendipity. A student ready to learn. what ever it is, I am answering the call.
This is what I have been searching for; Someone who actually does know what electricity is, and how it is correctly understood, defined, manipulated and applied; According to NT. DS and others of this elite field.
Here are three ED documents I have acquired today;
1 http://tinyurl.com/yh4eppl
2 http://tinyurl.com/ykj4vkc
3 http://tinyurl.com/yfolv69
Authors suggested by ED in the viedos:
Steinmetz,  Wheatstone, Sarnov, Bloom, Boiagen, Bulie, Kenely, Heaviside, Maxwell, Faraday and Mc Farlan.
Conclusion;
Needed is the actual arrangement of the signal coming from the plasma globe, or if it is already correct, we as followers have not found how to utilize what is there.
Don has stated to use the parabolic resonance signal, and the pulsed DC square wave from the Diodes. (This last statement is visually applied to the output of the table top design as most people call it. This is directly adapted to the secondary HV center tap sign transformer on the output side of the two hot wires.)  As far as I can find he has suggested no other comonly referred to electrical signals.
I am new to electronics so if I am wrong please set me strait!
I anyone has further documentation, videos or related Authors books mentioned above please post the links.
h2ocommuter
h2ocommuter
I have finally been able to manipulate the signal into a combonation AC and DC consistant signal where the DC is a consistant V top and Bottom (like a saw tooth but not bent over), absolutely no fine traces inside or outside, The AC has the spark chopping the complex waves in two. Another wild thing is the DC signal is hundreds of volts higher than the center line for the traces?
The electrostatic voltmeter works the same every time I adjust to this special position.
I am using the double grounded spark gap and taking the signal directly from the output side of the IT. This is also where I am using the electrostatic voltmeter.
The readings at that point are consistently 400 to 500 volts. Either one or the other. rock solid depending where I set the two gaps.
Any way I am feeling lousy so I decide to post the findings verbally and I will post pics and video later.
Note; I tested the scope with house current and voltage. The scope figures are not within the calibrated range. Or I just am confused about taking the readings.
My "B" Chanel does not work so maybe that is the problem.
The Manuel says to use the "B" Chanel but I figured the "A" Chanel would be the same.??
Nothing mind bending yet just improvements.
Good day
Zane
h2ocommuter
Ok.
After being sick for a week and going to work I have been all sucked out. Just feeling a bit better and needing to get back to the shop I had my camera all loaded up and did not feel well enough to take the shots I mentioned in my last post. no biggie.
I went through the steps with my circuit to see what the hell I had done. the process seemed to have something to do with the conical coil I put together and doubled back the amplification to the spark gaps. As I removed this to see if the amplification had anything to do with the electrostatic voltmeter working well I discovered a few other things that I have never seen before in my circuit.
Here is a video showing the ESV readings coming from the output side of the IT. http://www.youtube.com/watch?v=-aZy8MjgZRk
1480 Neg spikes, http://www.youtube.com/watch?v=lO4IdgI0nE8
Next and surely the next step after the last post is this one showing the strait DC voltage triggered pos signal and the deflection, or "voltage increase" caused by the spark gap distance through the imbalance of the circuit. http://www.youtube.com/watch?v=reuc-lklWcA
This last video is showing how I am finally! able to get a cap to violently discharge on its own.
http://www.youtube.com/watch?v=gq3wTYOPpdM
The last video is how the large speaker magnet effects the sparkgaps and what is surely possible when manipulating the magnetic spark apparatus. This has many possibilities and implications about how you want the circuit to perform. http://www.youtube.com/watch?v=x-FXrnmdd6w
With this view you could imagine what NT was doing with his circuitry.
That being said, I am speculating how he momentarily interrupted the abrupt discharge to produce various impulses.
Zane
h2ocommuter
Hi all,
The light bulb comes on.
As my last post mentioned I finally found the hot button to get the capacitors to automatically discharge.
well, today I found a silent discharge spark and a noisy discharge spark.
The silent one lights the bulb
The noisy one does nothing but get loud.
Here is the video and Yea the same old circuit. nothing but dull information but the system is producing more results.
I blew all my LED's so I did without them and found these results.
go figure.
From the amount of responces I have been getting, I must be on the right track.
I am very happy to be getting the reads.
Thanks everyone for the encouragement. It is something special.
thank you all
Here is the proof of discoveries mentioned. http://www.youtube.com/watch?v=2qC03Bqp7GA
h2ocommuter
