IST`S HIGH OUTPUT 0 ZONE GENERATOR 12VDC
Started by innovation_station, February 01, 2010, 10:40:58 PM
innovation_station
here is the ALI 4" coil construction video
cheers!
                 !! WARNING !!
          electric shock hazzard
service by qualified personnel  only
W
http://www.youtube.com/watch?v=hARy2Mu1vWk
innovation_station
afew pics ...
: 0
ist
NO MASS CIRCUITRY INVOLVED ..
its just the knowalage of the coils and how they interact!
innovation_station
so now we have a 4" ali coil ...
if i were to jt it as showen ..   and take off the back side of the jt as a normal jt to fill a cap through a bridge ...  it does this no problem ...  now  i have it in a cap and allow some buffer time ...  i could diode it out of the cap to the secondary coil
inputside and use the other end of the secondary with a diode on it and a negtive feed from the cap ..
wich is common to the battery in a npn configuration jt ..
ist!
innovation_station
im testing out this coil as we speek ...
so far it works quite well
i have been rechargeing a cordless drill battery from a aa
it uses a 2n 2222a tin can and 2 db107 bridges ..  the 4" ALI and a cap ...
i back loaded the jt with a cap ... REALLY THE VALUE DOES NOT MATTER AT ALL..!!
its more a regulator .... ; )
and i then attached another db107 to the secondary ...  and hooked it dirrectly to the cordless drill battery it is a 12vdc battery ...
so i also placed a neo on the ring ... in the right oreaintation ... it causes my battery to charge faster 1 way than the other ...
it took bout an hour to fully charge the battery ...
ist
im building it right up and will make a video ...
the_big_m_in_ok
Quote from: jadaro2600 on February 06, 2010, 02:42:45 AM
Approaching Superman are we?
..Won't you please post the schematics? ...are we to be forsaken?
I was hoping to build one without a great deal of copper, have you any alternative coils; do you have any suggestions?
I think jadaro2600 is right.  For me to actually see a schematic would be visually definite in my mind.
--Lee
