The Ossie motor
Started by robbie47, February 02, 2010, 03:53:17 AM
Bruce_TPU
Quote from: Jimboot on April 02, 2010, 02:48:32 AM
Really a weird field pulsing off the motor. You can feel it in your body from foot away. Should i be concerned? :) I've wound another bifilar coil to mags specs. I get around 10v in the cap. My winding is crap tho. I used a fishing reel to wind it, I think I need to buy an electric coil winder. Any recommendations? But have managed to keep rrpms close to 1000 whilst amps sit on 0 (0.009?). Voltage 1.303. Whilst typing next to this motor I can feel the shake of it through my arms. I have also used mags technique of polarizing the reeds. Weird new scope trace as well.
Hi Jim,
It has been said that very fast moving rotation of a magnetic field will actually spin the Ether.  As long as you have been spinning yours, non stop, I am not surprised that you feel a weird sensation near your motor.  Just my 2 cents...
Cheers,
Bruce
Jimboot
Magluvin
New rotor, how is it going?
Mags
Jimboot
Behaviour is sooo diff to the last one. More torque RPMs are down around 300 on 10DCmA & 5.2 volts. BUt it give me more room for extra pick up coils. I'm using a CDROM spindle & bearings from the computer fan. It is much more free spinning than the computer fan & takes a looong time to spin down. Still tweaking & tuning.
Jimboot
Hi All,
Been busy burning my fingers with hot glue, having motors fly apart at high speed winding coils, modified fishing rods etc.
I've setup a seperate Youtube channel for this stuff as my other channel is mainly for work.
Anyway 3 new vids http://youtube.com/user/jimboot2 My motor will drive a small 12VDC motor using 50milliwatts at around 2500RPM. I think I need one of thoise hub dynamos that Ossie had in one of his vids.
