The Ossie motor
Started by robbie47, February 02, 2010, 03:53:17 AM
Jimboot
my trace across the coils atm. Setting up to attach gen motor again.
mscoffman
Quote from: Jimboot on February 04, 2010, 11:00:37 PM
@futuristic this was posted on the Yahoo EVGRAY list
"cooling fan motors usually have permanet magnets in them, and you can feel
the notchy rotation to them as the cores in there line up with the magnets so there is some loss using a cooling fan motor as a chasssis unless that is differnt type of cooling
fman motor with no permanent magnet in there.
Also known as cogging. Losses can decrease with higher
RPM's.
Arthurs
Very much hope that Replication, but ,,,,,
Very much hope that has been completed to Replication a friend's release full details of the circuit, and the use of component inventory.
PS: Can I use the Bedini SG or the window circuit? Results will be better?
Thank you!
Jimboot
Working on the gen still. This is the coil, battery & LEDs out of a rechargable torch. Not sure what value the battery is. I'm hoping the action of the rotor mags will charge it.
toomanymiles
I really like your versions of this motor  :).
It looks like you have two rotors on top of each other, am i right? if so are they spinning in the same direction or the opposite?
Can you tell me what you use to build your rotor.  It looks like it cruises pretty fast.
Thanks in advance for answering my questions.
Scott
