The Ossie motor
Started by robbie47, February 02, 2010, 03:53:17 AM
Jimboot
this rotor is N/S so I'll have a look. Thanks could be just what I need to get this thing running even better. Iwas looking for a mag potentiomer early in the piece. Volts at the cap 18.05. Pretty low current tho given earlier experiments.
Jimboot
@mags you've spoiled it! I want 70v now :) My thought it is I f I get this to charge quickly and use a diode to pass the charge to the battery when it reaches 3v I should get rapid 3v pulses into the battery. But I need better pu. You were right. The drive coils way out performed the torches I bought once I attached the reed. I notice you said yours was bifilar so I will be studying those today when I get a chance. Using the reed across the pu coils does increase drag on my rotor so I have to run it at around 0.01A to get the rpms up.
Magluvin
Hey Jim
Really the rpms being high are not that important. The coil i used in the vid used RS 30ga  2 rolls of 200 ft ea. wound bifi. Then another coil on top just use som other wire I had.
My motor in the vid is not running that fast. And it does slow down with the gen. The green coil is RS wire also, 2 rolls of 75 ft on 1 bobbin, not bifi though, just 1 on top of another.
You say your rotor mags are alternating N and S out?
Mags
Jimboot
I just got distracted. I was passing a mag near the motor and it sped up. I then grabbed another mag. Faced the opp pole on the opp side of the motor and peed increased greatly. I was initially intrigued by George greens demo of the ball bearing and mags but then discounted it as the movement in his hand causing the rotation of the bearing. But maybe there is an effect similar. My rotor mags arem opp poles. Reconf my rig.. again. Btw my bifilar coil performed badly.With the mags tho I reckon I trebled the rpm with the consumption staying around a milliwatt.
Jimboot
Thanks Mags, yep N/S poles. I have a mag about 75mm (3") above the rotor and it has doubled it's speed whilst not using any more power. Voltage b4 going to bed was 1.177 This morning it was 1.184. I'll buy some more wire today. I have just bought a coil winder. My wife tells me that apparently it will also peel apples :)
