Steorn's Patented Measuring Device & SKDB
Started by gravityblock, February 12, 2010, 01:22:05 AM
gravityblock
Here's a patent from Steorn:  http://www.google.com/patents?printsec=abstract&zoom=4&pg=PA3&id=1dOyAAAAEBAJ#v=onepage&q=&f=false
Inventors: Sean David McCarthy, Alan Simpson, Martin Flood, Maxime Sorin
US2009/0009157 A1 : SYSTEM
AND METHOD FOR MEASURING ENERGY IN MAGNETIC INTERACTIONS:
  An apparatus and method is provided for measuring magnetic force response time due to the magnetic viscosity of materials and for measuring total energy exchanged due to relative motion of magnetic materials. Voltage and current versus time through an electromagnet is measured and recorded.....
The SKDB may teach us how to build and use the patented measuring device mentioned above in order to perform tests on the materials so we will know the optimal parameters and are able to match the materials in a successful replication, thus the reason for the hard disc drive tolerances.
I think this device needs to be explored along with the other information in the SKDB.  I will post the main parts of the SKDB in the next post.
GB
gravityblock
Some of the tools for testing noted below is used in the patented measuring device.  This is the reason why I think it is essential to research the patented measuring device because it may be necessary for a successful replication.  Also take note how it mentions Homopolar Motors and Generators under "Rotating Electromagnetic Systems".  CLaNzer decided to build a Pulse motor and Homopolar generator combination and I believe he is part of the SKDB, http://www.youtube.com/watch?v=b2I6sOc056k
e-Learning (Basic physics of Orbo)
Physics Primer
1)  Atomic Structure
2)  States of Matter
3)  Force, Energy, Work, and Power
4)  Forms of Energy
5)  Newtonian Dynamics
6)  Intro to Electricity
7)  Intro to Magnestism
8)  Intro to Thermodynamics
9)  Frames of Reference
10)  Resonance
Rotary Systems
1)  Key Concepts in Rotary Systems
2)  Coupling and Pure Momentum in Rotary Systems
Magnetism
1)  The M-H Curve and Magnetic Domains
2)  The Magnetic Force equation
3)  Magnetic Effects
1)  Forward and Back EMF
2)  Electromagnets in Detail
3)  Homopolar Motors and Generators
Tools for Data Analysis
1)  Statistics
2)  Calculus
Tools for Testing
1)  Oscilloscopes
2)  Angle Encoders
3)  Torque Sensors
4)  Displacement Sensors
5)  Thermocouples
6)  Hall Probes
7)  Data Acquisition Systems
Orbo
1)  Conservation of Energy in Classical Permanent Magnet Interaction
2)  Conservation of Energy in Electromagnet Interaction
3)  An Electromagnetic Orbo Interaction
[Edit:]  The above information was taken from the "SKDB learning resources" from SteornOfficial, http://www.youtube.com/watch?v=su3T7NFs85U
GB
gravityblock
What goes on in the Steorn SKDB Part 1, http://www.youtube.com/watch?v=O1reS5ANxjg
What goes on in the Steorn SKDB Part 2, http://www.youtube.com/watch?v=SVBcdEn-xa0
What goes on in the Steorn SKDB Part 3, http://www.youtube.com/watch?v=W_1EcQcvkQc
What goes on in the Steorn SKDB Part 4, http://www.youtube.com/watch?v=Ev0B-_2PcMk
GB
gravityblock
There's been a lot of talk about the B-H curves in the other thread in relation to the core material.
The SKDB materials for the Orbo talks about the M-H Curves.  This needs to be researched.
GB
gravityblock
An Angle Encoder is mentioned in the SKDB material for tools needed for testing.  This is used in the Patent Measuring Device.
A rotary encoder is an electro-mechanical device that converts the angular position of a shaft or axle to an analog or digital code, http://en.wikipedia.org/wiki/Rotary_encoder
GB
