Pulsed DC Transformer with Embedded Magnets
Started by ltseung888, February 24, 2010, 03:55:56 AM
nightlife
 Something doesn't sound right here. If this truly produces overunity, then why are solar panels needed? Why is there a need for outside input power? It should be able to be started with a simple pulse and continue to run on it's own without the need for ever needing an outside power source.
It sounds to me like this is just another type of Jule thief.
For all you overunity pulse technology seekers. Keep in mind that to achieve such, you should never need to provide any more power then just a turn by hand to get the devise up and running. No input power should be required other then just one simple pulse. This means that we should not see any battery's, cap's and or any other storage devises being used at all times to power the devise.
ltseung888
Quote from: A on February 25, 2010, 08:36:13 AM
Dear nightlight,
You are assuming that the invention has been perfected to a high degree of sophistication.  In the ideal situation, only a starting energy is required.
However few of the listed inventions are at that stage yet.  For example, the theoretical output of the Tong Wheel was calculated to be 150 watts and higher.  The actual experimental output measured was only 2-3 watts.  The extra output was not large enough to recharge the batteries.  Thus the removal of the battery will stop the device.  However, the RMS values of the Volt and Amp meters can confirm that Output Power is more than Input Power.
You have to be more tolerant to the prototypes.  Nobody has build a working FLEET yet.  Mags only demonstrated that case 3 can be better than case 2.  He then realized the magnitude of the task and that he did not have all the tools to do a proper analysis.  He waits for the Professionals to complete the task.
The transformer manufacturers usually use short-cuts.  Do the minimum to get a product to the market.  We may need to wait for the Hangzhou Research Center to do the vigorous scientific experiments.
However, that does not deter any of you from having some fun â€" Mags had his share of the challenge and fun.
FatBird
EXCELLENT POINTS Lawrence.
It is SUPER NICE of you to try and HELP THE WORLD.
Thank you for all you do sir.
nightlife
QuoteThe actual experimental output measured was only 2-3 watts.  The extra output was not large enough to recharge the batteries.  Thus the removal of the battery will stop the device.  However, the RMS values of the Volt and Amp meters can confirm that Output Power is more than Input Power.
WRONG! You can not rely on values that are not precisely accounted for and if it truly produced more, then it would run on it's own without the need of a battery and or any other outside source other then what is natural and or magnetic to keep it running.
As for having fun, I am all for that but having fun and instilling false hope are two different things.
Prototypes are needed as well as testing and I support them but I do not support any false claims nor do I support any allegations of such. True overunity should never be claimed unless it truly runs under it's own power and still produces excess power above that.
Paul-R
An alternative FLEET configuration:
Could not the two windings be brought down to the bottom, and then be replaced with a centre tap winding? Such an item might be found off the peg. It only remains to cut an aperture out with an angle grinder to fit magnets.
