Electrical igniter for gas engines A keystone to understanding by Magluvin
Started by Magluvin, March 01, 2010, 01:30:50 AM
forest
Magnet is another idea, extendin the basic IMHO.
for example : http://jnaudin.free.fr/2SGen/indexen.htm#hysteresis
Seems that adding a magnet to the core of coil in proper position will enlarge current generated when coil magnetic field is collapsing.
forest
I have two ideas related to Tesla igniter patent :
1.  Capacitor can recharge very fast due to high self-induction coil having current flowing already in it so current not need be rised from zero volts to charge capcitor.
2. When capacitor discharges ,coil magnetic field also collapses from high -self induction coil and PUSHES electrons from capacitor so the RESULTING CURRENT IS LARGER, meaning a little bit more power.
forest
The second point is interesting : if we have two coils and only one have magnetic field and we short them in series to the power source , does magnetic field BALANCE ITSELF  among those two coils  like electric current among two capacitors ?!!!
I think this is important!
Tito L. Oracion
Quote from: forest on March 28, 2010, 08:54:59 AM
A few thoughts :
1. There are two switches there : when capacitor is charged IT IS DISCONNECTED from power source and connected to load.Unidirectional energy flow - not killing the dipole.It sounds strange but that assume that there is signal propagated back to source which drains it ??
2. When capacitor is connected to the battery it is charged  slowly through the diode.When capacitor is charged CURRENT STOPS FLOWING FROM POWER SOURCE.This is very interesting.
If we  add a coil in series to the led diode what will happen ?
I will test it surely, I will - IT IS SO INTERESTING (unfortunately I'm on trip now and cannot confirm that) - what I think will happens is that :
capacitor will charge , led light diminish , BUT ALSO COIL CREATE MAGNETIC FIELD
,and if I'm right that magnetic field will be FREE ENERGY but hard to tap :-(
Now when capacitor is shorted and discharging  , DOES IT MEAN ALSO COIL DISCHARGES ITS MAGNETIC FIELD INTO LOAD ? OR magnetic field from coil will collapse charging capacitor so the next time ONLY SMALL AMOUNT OF ENERGY WILL BE REQUIRED TO ADD CHARGE TO CAPACITOR FROM POWER SOURCE ?
Many questions ....
Can we add loop circuit around coil with a switch to short coil at proper moment to prevent dissipation of magnetic field ? we could then discharge capacitor into load and then collapse coil magnetic field into capacitor to see if there is any gain here...
Your getting good tarzan  ;D
Thats my boy  ;)
Your really thinking.   ;)
salute you  :-*
Try to remember one tip i gave you and that's it.  ;D
what tip? oh boy i forgot it. sorry  ;D ha!ha!ha! joke.  ;D
We don't actually needs an electron to charge a cap ok!
what we need is a faster separator of charge, then battery will replenished itself, though there's a slight lost but we can back trickle charge it to maintain its sleeping beauty. ha!ha!ha!ha!ha!  ;D
so that rincles will be in controlled.
always smile don't be very serious ok everything is under control ok.  ;D
ramset
Thanks Grandma
