Electrical igniter for gas engines A keystone to understanding by Magluvin
Started by Magluvin, March 01, 2010, 01:30:50 AM
the_big_m_in_ok
Quote from: baroutologos on March 26, 2010, 07:04:42 PM
Nice to hear you are on it mag. On the other hand Baroutologos cann sit idle can i?
Speaking of coils and tails, look at my cat's tail? Ha ha! :):)
ps:formal presentation will follow
How much voltage will it produce?  And current draw from the power source?  Impressive looking unit, though.
--Lee
delboy
@baroutologos
"Speaking of coils and tails, look at my cat's tail? Ha ha! :):)"
Speaking of loose connection between primary and secondary , it does'nt mean that primary should have so big spacing from secondary !!! You are loosing energy in that spacing, magnetic field is droping with square of distance! Primary should be in tight connection with just few turns of secondary, for example 3 turns of primary are in good connection with 5 turns of secondary, because you want to transfer all that energy from primary to secondary to get another resonant circuit with HV high frequency (another RLC)! That 5 turns of secondary become new source of high frequency in secondary (another RLC)!
But I'm speaking about 5 of 50 turns in secondary, not 5 of 2000 !
baroutologos
Delboy,
I have made measurments today regarding the coupling coeff. of primary to base drum coil. It has a loose unacceptable coupling coeff. of 0.22-0.23. (WRONG)
-deleted-
I made an error in my calculating formula. Using a software created by Mark S. Rzeszotarski, Ph.D. the Coupling coefficient of my coils (drum-primary) is approximately 0.7
baroutologos
Hm... i saw the videos.
I am really disapointed from you Tito. Those videos are noob mistakes that every noob-free energist wannabe (like us) have made in the past.
I hope you are not serious on those...
