Electrical igniter for gas engines A keystone to understanding by Magluvin
Started by Magluvin, March 01, 2010, 01:30:50 AM
woopy
Thank's P.99 for the link it is very informing as the whole content of this link.
If i understand well, the reactance is applied in sinusoidal or AC input. So the inductor in AC  does not consume energy.  Does it also apply in DC ?
Hey Mag
I tried today  in the sim, to stack on your circuit, 4 series of" * resistance 2 ohm and inductor 220 mH and cap 10 uF " all that in serie in the  "believe circuit."
And almost each time i try it, the the soft does not converge. It seems that when the result should be more than 100 % the soft collapses ?
Please have a try and let me know.
than i tried in real life with 2 MOT and 2 reciever cap in serie. and i got also interesting results. The result is far better with the inductor in serie as per direct transfer. I wonder if we stack more of those serie of Cap-inductor, what would the result be?
good luck at all
Laurent
forest
friends
do you remember modification of Mags circuit I posted with continuous oscillation between coil and one of plate of capacitor ?
I BELIEVE that tiger2007 posted circuit is a variation of this effect and this is real free energy , yet with very small amplitude in simulation.
HOWEVER remember that simulation is describing hypothetical coil , not the one with FINE FERRITE !!!!
tiger2007 circuit show amplitude up to 10volts from initial 12V battery impulse
I think this is the correct effect to investigate. Just simulation won't help too much. The dumping of capacitor is just by-product when blocking self-running oscillator is done.
woopy
Hi Mag
just a ( very bad ) picture of the modif on your circuit But you will understand no problem.
the DC input voltage in the main  10 uF cap is 1000 V
the resistors are 2 ohms
the inductors are 221 mH
the caps are 10uF
please try it , very interesting indeed
Laurent
Magluvin
Hey Forest and Woopy
Can you give a link to that circuit Forest?  ;]
Ill try anything. =]
Woopy  Are we looking for the charge that is on all the caps?  ;]
Ill put the circuit to the sim in a bit.  Just got home from work.
Ok  shower and eats.
Back in a bit
Mags
ramset
Forest,
It is very hard for me to understand what Tiger 2007 is claiming?[on his Forum[Link below]]
Can you interpret ??
This is a post From "Choose user name" RE : Tiger 2007 [On the TK thread today]
Quote:
BTW,
another one selfrunning device by Tiger and his comments here: http://www.youtube.com/watch?v=bcftGrBEaL0
The creator is fully open to all and makes no secret. After some work, the bulb can be connected as it is so at the link above. That's beginning ;)
discussion here: http://bit.ly/hD2W5m
Chet
PS Mags
SUP!
Thanks Grandma
