The Owl , rotation defeating gravity
Started by Cherryman, March 04, 2010, 06:05:14 AM
BEP
I don't think I meant to be sarcastic. My point is: Sure, it will work. The problem is the amount of force needed to counter gravity (force). Since the vehicle or device will be small the velocity and changes in direction must be large. Such movements would vaporize any traveler.
It is like Ohm's law. You can get the same amount of Watts with high voltage and low current or low voltage and high current. The difference is you must also consider time.
Try much larger masses of the device and lower gravity. You should see less velocity needed by the moving parts to achieve the same distance in movement.
