Muammer Yildiz Magnet Motor
Started by penno64, March 08, 2010, 03:02:32 AM
Omnibus
Quote from: TechStuf on April 22, 2010, 04:54:06 PM
One has only to look at the patent schematics to see that the dynamics at work are genuine. The 'magic' happens at high speed, kind of like driving your car over a street made of speed bumps. Go fast enough and things get smooth.
What is occurring in the Yildiz motor, is that myriad field 'bumps' produce copious eddies at very high frequency.  His motor has, no doubt, an RPM sweet spot, necessitated by it's current design.  A few modifications and his motor is ready for prime time.
Who knows, it might be already....
TS
These copious eddies are brakes rather than stimuli. How do breaks become driving factor?
TechStuf
QuoteThese copious eddies are brakes rather than stimuli.
Tell that to the fish who use them to remain motionless in a swift stream, even darting upstream at great velocity and with little effort.  Or the Bumble Bee who sheds them with great efficiency....or even the bacterial flagellum.
The PMs that are causing the vortices need not be the ones caught up in them.  All too often, magnetic fields are summarily relegated to bipolar status, while somewhere in that huge gulf in between, exists the dynamic lever by which to pry loose one of the covers on nature's wheelwork.
TS
“For the wisdom of this world is foolishness before God. For it is written, “He is THE ONE WHO CATCHES THE WISE IN THEIR CRAFTINESS” - 1 Corinthians 3:19
http://www.freemasonrywatch.org/sixpointedstar.html
http://www.youtube.com/watch?v=XBjOs-egFMs
http://www.youtube.com/watch?v=_WSGwnz7XpY
http://www.youtube.com/watch?v=l39XsMcyvgA
http://portland.indymedia.org/en/2004/09/297062.shtml
http://www.youtube.com/watch?v=JjjIy1DO0gs
We all have the choice to waste ourselves in rebellion or to gain wisdom.  Therefore, gain wisdom:
http://www.hisremnant.org/eby/articles/kingdom/twohands/twohandsof.html
sigmaX
I found these links in the web about the inventor:
http://www.rexresearch.com/yildiz/yildiz.htm
let me quote some text .... (go to the link the get the whole story)
Technische Universiteit Eindhoven [Eindhoven Technical University]
Department of Electrical Engineering, Electromechanics and Power
EUT_JD2005_2.doc (7-28-2005)
Experiments on an Apparatus Intended to Generate Electricity without Physical Connections to Other Power Sources by J.J. Duarte
This technical note aims at describing a test I personally conducted in Izmir, Turkey on July 17, 2005. The purpose of the experiment was to check the energy balance with respect to input and output of an apparatus, which was the embodiment of the invention described in international patent WO 2004/091083 A1.
The apparatus was confined inside a metallic box, and I was allowed to inspect everything outside this box. However, in order to protect the core ideas of the invention, I was not supposed to check all the details of the internal parts. According to the inventor the apparatus is predominantly a mechanical system, without any kind of energy storage inside the box like batteries, accumulators, flywheels, combustion motors, chemical or radioactive reactions. I believe the intentions of the inventor were in good faith.
The experimental setup was quite simple, as shown schematically in Figure 1. It consisted of placing the box with unknown contents, from which DC voltages and currents were expected to be generated, on a table in the middle of a room. From the box, a cable with two terminal contacts was available for connecting electrical loads. I placed measurement instruments between the box output terminals and the load. The load consisted of an ordinary AC-DC inverter, this inverter being connected to an incandescent lamp. The working principle of the inverter and the lamp type were not relevant for analyzing the results, because the output power delivered by the box was measured immediately after the output terminals. Photographs of the setup are included in Appendix A.
etc etc.
I cannot find anything about him claiming to be a fake / scam, but only references about him being in the "scene" with apparently revolutionary ideas and trying to make them known ....
What is going on ? If this guy is a scammer, by now such fact should be known...
On the other side, if he had a "miracle" mechanical / magnetic self-contained power generator back on 2005, even tested by this guy apparently from an university .... well he should be definitely rollin' on money / fame by now!
Weird enough!
Omnibus
Quote from: TechStuf on April 22, 2010, 06:28:45 PM
TS
It's not a matter as to how fish remain motionless. The problem here in this motor is where is the energy to sustain that purported stream coming from. If there's no external energy input there is no stream. If there is external energy input and stream is created the machine may or may not be OU. This, however has to be studied rigorously, not by just seeing it rotate or placing a fake wind tunnel to measure who knows what. It isn't at all obvious at this stage that the motor presented is an OU machine especially because of the suspicion that there is an undisclosed energy source inside.
TechStuf
QuoteIt's not a matter as to how fish remain motionless.
To which I reply....it's all 'relative'.
You say potato....I say, spud.  You say OU....I say UO...
Yildiz says, "pay up".
What else is new.
TS
