Muammer Yildiz Magnet Motor
Started by penno64, March 08, 2010, 03:02:32 AM
Quote from: profitis on April 11, 2013, 09:51:45 AM
yes @tinselkoala but if we just had a infrared snapshot of the whole device we could tell if a battery is embedded in the motor because it would show up as a hotter part of the image where the bats are located.if it showed the case of the motor as cooler than ambient then i would tend to rule out batteries and start to think in terms of a 2nd law violation.
I have nothing against data; the more the merrier. I think there's a lot of thermal mass in that thing, though, and you might not be able to pick up a battery's heat through all that stuff. X-rays, CAT scan, backscatter, there are lots of ways but do you seriously think Yildiz would permit anyone to use them?
I am reminded of the fancy thermal imagery from the Steorn Waterways demonstration. Yep, sure enough looky there, the coils are hotter than the rest of the thing. They must be because the imagery shows them in different colors. And that is all that is ever heard about thermal imagery. No calibration data, no comparisons, nothing. Thousands of dollars worth of kit, for a few seconds of colored pictures that make people nod their heads sagely, stroke their beards and glance furtively at each other.
synchro1
Quote from: TinselKoala on April 11, 2013, 10:55:37 AM
Can you give the link to where that can be seen? I can't stand to watch any more of those fracking ads looking for it. This is the most boring demo ever.
Reads 2037 r.p.m. from the back of the shaft 1:10 into the video: This shows where he's taking his tach reading from.
http://www.youtube.com/watch?v=AMYy4nioQXM
OK Thx.
The online calc gives 22.2 Watts for the APC Sport 16x10 at 2037 rpm and the default air data.
Six candy bars.
Gwandau
Quote from: Bertoa on April 11, 2013, 07:58:27 AM
Yildiz' All-Magnet Motor at the Inventors Expo in Geneva is not functioning right. I know something would happen to 'disturb' the 5 day continous running. This validation is not going to happen. The list of fraudy FE inventors will become longer by Yildiz contribution. Do we have to go on with giving attention to his 'invention'? I did know something was going wrong with this.
@ Bertoa, I can't but agree. It all smells funny. Below is an excert from Sterling Allans report made yesterday in Geneva:
"This morning, when Mr. Yildiz went to start the motor at around 10:05 am, shortly after the conference opened, it didn't start. He pulled it into a closet at their booth for about 20 minutes, then emerged. Then he started it by the way you've seen on the web.
The motor ran from 10:28 am to 2:50 pm GMT, nearly 4.5 hours.
It started at 2600 rpm, then went up in speed to 2673, then down and up that range for about 3 hours.
Then, a magnet was "loose", and the motor began to slow. Then, he said that the magnet alignment malfunction began to cascade so that 3 were out of line. By 2:21, the speed was 2064. A noise could be heard from the motor, so he turned it off.
Then, at 3:10 pm, he turned it on again, and it went to 1930 rpm, then began dropping rapidly
1734 rpm at 3:12
1522 at 3:15
He stopped it at 3:16 pm
The temperature was around 23 degrees on the front and back bearings, just 1 degree C above room temp: 22 C
So presently, the motor is off.
He plans to work on it this evening, then run it again tomorrow, hopefully all day (and hopefully through the night too). "
Regarding the eddy fields and heat production expected to be present when moving magnets within a aluminum body such as the Muammer Yildiz motor,
there was no excess heat detected.  But there was something else that Sterling Allan noticed, something quite peculiar:
"Also, yesterday, Yildiz demonstrated an effect in which copper coins (which normally are not attracted to magnets) stuck to the outside of the magnet motor, while silver-colored coins (which normally are attracted to magnets) drop off the outside of the same motor body -- the opposite of what you would expect. This illustrates that there is something very unusual going on."
Now, I really would like to know if Sterling A had the possibility verify the copper colored coins to actually be made of copper, since if they were, we are here confronted with hitherto unknown effects. It openly violates contemporary scientific knowledge, copper just do not stick to aluminum, no matter what's going on inside.
This last observation about copper coins sticking to aluminum makes everything become uncertain again.
Is this little strange man genuine, or not?
Gwandau
ramset
Gwandau
latest on the coins
all is as it should be no nonferrous attraction!  I think the "Sterlinga" said this today,and added that it was all magnetic and good news !!
@Tinsel
Can I get Chocolate Chip cookies instead of Candy bars? [whats the swap rate on those?]
thx
Chet
Thanks Grandma
