Fibonacci, platonic solids and Vortex coils
Started by Mk1, March 09, 2010, 10:39:44 PM
Mk1
@DonEMitchell
First off welcome to this tread , its all about sharing ideas so feel free to post any idea ...
Thanks for the link and pictures and expertise , i am willing to learn everyday.
I see what you mean , i will need to think about it before making any relevant comment , the funny thing is i had some similar ideas early this morning , synchronicity .
Kind regards
Mark on earth  ;)
Cherryman
Maybe i'm way of the point here, but i did came to some relating info i think that could add some info.
QuoteLi explains that as the ions spin they also create a gravito-electric field perpendicular to their spin axis. In nature, this field is unobserved because the ions are randomly arranged, thus causing their tiny gravito-electric fields to cancel out one another. In a Bose-Einstein condensate, where all ions behave as one, something very different occurs.
Spinning ions - that' s what my email below is about (see red text).
I think I can explain what those cone-shaped holes and mirage heat waves are, but first let tell you a little about myself. I'm 30 now. When I was about 18, I saw a strange light in the sky that looked like a red ball of light. As I was looking, it shot out of sight in the blink of an eye. The first question I asked myself was not "What was that?" I asked, "How?"
Sense then in my spare time, I've researched the how question. Without getting too technical, I came to conclusion that an electromagnetic field can cause an antigravity effect IF the fields are shaped properly. There are actually two fields that need to be shaped properly. The electrical field and the magnetic field.
The electrical field has to be shaped like a tornado or a vortex. The magnetic field has to be shaped like a donut. If you can make a device that can create the electrical vortex, then the electrical field will cause the magnetic field to take the donut shape. The same is true the other way around. If you had a device that can make a donut-shaped magnetic field, it will build the electrical field in a vortex shape. These shaped fields cancels gravity.
Another thing to mention that might explain what Ricky Sorrells saw. It's known for a fact that gravity bends lights. It's part of the theory of relativity that gravity can slow down time and cause mass to change. These are relativity facts.
Now, we can explain Ricky's drawing. Each cone-shaped indention is a device that creates an electrical vortex (sometime called a plasma or ion vortex), and like a tornado with multiple vortexes, they all the add up to cause one big vortex around the craft. That big vortex causes a large donut-shaped field around the craft. Within this donut shaped magnetic field, magnetic flux lines are created in a little different shape than normal matter. Flux line are the force lines in magnetic fields. You can see these flux lines if you sprinkle metal shaving over a piece of paper with a magnet under it. Flux lines are always curved, except in the center of a donut-shaped field.
And while "floating" .. I add this ;-)
http://www.ufohowto.com/Magnetic%20vortex%20wormhole%20generator.pdf
tysb3
hi Mk1,
some suggestions about coils. I don't try it yet, but I will.
I was away from my toys, but my mind was always on double JT :)
this coil is easy to fix.
this is clip, how to wind coil:  http://www.youtube.com/watch?v=1i5vVaKGJSM
guruji
Hi MRD10 nice setup there. Does it give certain ammount of power there?
I really need a setup of a small JT that can charge a bank of batteries.
Is there a hero there that can do this? :)
Thanks
