PWM circuit 555
Started by Artic_Knight, March 17, 2010, 12:18:09 PM
Artic_Knight
please define no special benifits.
i added a pinch of baking soda and it increased production dramatically in my cell while i was only drawing what seems to be 90 mah. dont know for sure till i check it under a scope (dont have one)
Paul-R
Quote from: Artic_Knight on March 26, 2010, 11:35:08 PM
please define no special benefits.
The electrolyte has specific functions, principally to allow electrons to flow
through the system. The solution must, at least, have ions. Both baking
soda and NaOH pass this test.
However, under electrolysis, Baking soda based electrolytes have given off
carbon monoxide. If this is what you want, then use baking soda.
crowclaw
Quote from: Artic_Knight on March 21, 2010, 03:43:27 AM
has anyone else worked with aluminum? i seen one mention of it in this forum but didn't see much more.
I believe for serious production volume where you need to up the power you'll probably find ali plates will not last. The most commonly used material is high grade stainless steel, and this is the material I used. My cell was running just under 8amps at just under 100volts.
haithar
what unit is mah? and are you talking about an oscilloscope?
haithar
what is the 42,8kHz supposed to do to the water molecule?
