Bruce's Discovery, Tesla's Missing Link for his Unipolar Generator!
Started by Bruce_TPU, March 21, 2010, 07:22:45 PM
Bruce_TPU
Quote from: Airstriker on April 19, 2010, 09:51:35 AM
Hi Bruce,
Any chance of seeing this letter and graphs you're talking about ? Thanks in advance.
Hi Airstriker,
I have it in PDF form but it is too large to upload.  So I have turned each of the 5 pages to JPG's to post here.
The graph I need to find again... for some reason I did not save it.  But I will and post it. I want it for my research file.
Hi e2matrix,
The same reason that ferrite increases induction, greatly!  Except with flat pancakes, it is a weird thing to think about.  It is a thin layer, that should "magnatize" and strengthen the flux field, resulting in greater production of power. The presence of the core can increase the magnetic field of a coil by a factor of several thousand over what it would be without the core.  I am only putting it on the coil side away from the steel plate.  I don't need it on the coil side facing the magnets directly, because there is a steel plate there.  So I will have a thin coat, between all adjoining coils.  It will not hurt, but may help, even a little.
Hope that helps to explain my thinking,
Bruce
gravityblock
Quote from: Bruce_TPU on April 19, 2010, 08:14:03 PM
Hi Airstriker,
Bruce
Thanks Bruce.  I uploaded the pdf document to Scribd for my collection, http://www.scribd.com/doc/30211202/Nikola-Tesla-s-Free-Energy-Documents
GB
gravityblock
@Bruce and All:
An analysis of the inventions intended by Tesla, on the reference you posted, is found in "The Second Law Thermodynamics and Tesla's Fuelless Generator", by Oliver Nichelson, http://www.scribd.com/doc/30212011/Tesla-s-Fuelless-Generator
I find it interesting how the analysis by Nichelson, talks about the displacement current.  I have been studying the displacement current from the same author of the "Paradox 2 experiment".  In this paper, on the "Maxwell's Displacement Current", http://www.distinti.com/docs/maxdispcur.pdf , there is an experiment to test the validity of Maxwell’s Displacement current term.  The experiment showed that there is no magnetic field generated by the displacement current (I hope you study this experiment).  Displacement current is simply another way to say capacitive coupling.
I hope this post isn't going off-topic, but I think the information on the displacement current along with the analysis of Tesla's document, by Nichelson, could be helpful.
GB
sparks
    I have been researching thermo electric conversion.  Still working on the math.  But intuition is telling me if a gas is ionized the excited electrons will have the kinetic energy of the parent neutral atom added to the free electron velocity.  The free accelerated electron is now responsive to magnetic lines of force or electric fields whereas the parent atom was not.  The energy expent in 1st order ionization of a "heated" atom may well be less than that displayed by the excited electron velocity.  The accelerated electron will orbit a magnetic field line whereas the neutral atom will not and create a vectored current.  The photons emitted by an electron slowing down or cooling may be of the proper ionization frequency to cause additional ionization of nearby atoms resulting in an electron cascade event.   When conducted in the presence of a magnetic field a high current pulse beyond the input energy is effected.  It may be difficult to cause heated things to unheat things but it may be possible to add a little order to the randomized kninetic energy of a heated medium.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
wings
Quote from: sparks on April 20, 2010, 12:58:51 AM
Boyd B. Bushman
Lockheed Corporation
http://www.google.com/patents/about?id=wOUhAAAAEBAJ&dq=bushman+thermally&rview=1
same man:
http://www.youtube.com/watch?v=eckSEyeIuRk&feature=related
