Bruce's Discovery, Tesla's Missing Link for his Unipolar Generator!
Started by Bruce_TPU, March 21, 2010, 07:22:45 PM
Bruce_TPU
Happy Saturday evening everyone,
This evening I have completed winding my third coil.  Tomorrow I will start on the fourth.
I have determined that I will indeed need to sand all of the coils down, after fiberglass and black iron oxide, in order to hopefully fit 5 coils within my 1.25" self inflicted limit of seperation between the N and S facing plates.  There is no way to put in 8 coils after the fiberglass and iron oxide is added.  So I will set my sights on five coils, and that only after sanding everything down smooth.  The little bumps are small, but when on both sides of all of the coils, it eats up my space.
Cheers,
Bruce
Bruce_TPU
Hello ALL,
Fourth coil is now wound, and coils 1 and 2 sanded.  I will pick up some more wire tomorrow and begin to wind the final coil.  After, I will epoxy two of them with black iron oxide and the last one will not have any black iron oxide.  This way, we go, magnets North-coil-oxide-coil-oxide-coil-oxide-coil-oxide-coil-South magnets.
Cheers,
Bruce
Bruce_TPU
Hi GB,
I came across this set up and liked it, for friction free bearings.  Now, my set up is much larger and heavier, but do you think with strong enough magnets, I could still make it work?  It is very similar to my initial idea.  Thoughts?
http://www.youtube.com/watch?v=tcacRwjsY7w
Cheers,
Bruce
innovation_station
bruce ...
i have exposed the truth a long time ago ..
i did not to bother to read this entire thred i made it only a few words ...
so
the copper disc is sectioned .. look at the shape ... it is the power generator  witch operates like a jt ..
the hpg generates low volts high amps this is then intrupted via the split in the disc ...
hummmmmm
ist
my kick ..
regards
gravityblock
Quote from: Bruce_TPU on May 02, 2010, 10:45:04 PM
Hi GB,
Cheers,
Bruce
I do think it would work with strong enough magnets (I have already done testing on this).  Having a vertical axle definitely works better in my opinion though.  You can replace the four individual bottom magnets with two ring magnets in order to have a radial force around the entire shaft for better stability.  Steorn's ZeroF Magnetic bearings aren't much different than the concept in the video.
GB
