The Problem With Free Energy Ideas
Started by Eighthman, March 27, 2010, 09:30:19 PM
lumen
Quote from: exnihiloest on May 26, 2010, 03:18:26 AM
Not false.
The universe is governed according to the principle of least action. Events and actions tend to minimize the energetic configuration of the world. Therefore gurus blabs like Bearden's on ZPE (minimal energetic state of vacuum) will not be enough for discovering the trick, they are even counterproductive. The only possible way is to find a hidden energetic source higher than the environment and to exploit the differential.
The only possible way is to find a hidden energetic source higher (or lower) than the environment
giantkiller
You can choose to drink out of the glass once or pour it down the well to prime it and get copious amounts.
z.monkey
We're not ready for Zero Point energy...
Regular energy exists all around you...
All you need to do is build a simple apparatus to harvest it, easy man!
Windmill, Waterwheel, Solar Cell, Voltaic Pile, Thermopile, Nuclear Resonance Coil...
See, Easy!
Goodwill to All, for All is One!
exnihiloest
Quote from: z.monkey on May 26, 2010, 05:26:24 PM
See, Easy!
easy only to light leds, not to run aluminium factories or to flight planes.
infringer
maybe we can approach things like this matter following a cryptographic scheme the larger the matter the longer it takes to decode the more gravity created from the extra overhead energy it takes to decrypt....
Find the master key... weather the cryptology is a key or something more simple like frequency hopping... I dunno it all is greek to me what you guys were thinking but it appears that everything is a constant see of energy in tune with something...
Resonance tells us even if something is constant so IDK that we are thinking correct maybe everything is locked into one tune and gets information from that one tune but the rest is encoded somehow so we need a middle man type attack to approach the problem... Maybe the key lies in something so tiny we will never be able to physically see it but in order to be something physical it takes much energy to remain a solid object. Where something get this energy to last so long like a solid metal pole answer the surrounding enviornment through many interactions we only under stand at a larger scale. http://en.wikipedia.org/wiki/Iron_Pillar_of_Delhi This is over unity due to conditions this pillar has lasted for centuries long then it should have out in the open ....
PS DO NOT TAKE A WORD OF ANY OF THIS TO HEART!!!
I am half asleep rambling!
REGISTER AND BECOME A MEMBER RIGHT NOW!!!!!
........::::::::: http://www.energyinfringer.com  :::::::::........
"""""""everything is energy and energy is everything""""""
-infringer-
