GBluer(Slayer) Exiter
Started by slayer007, March 28, 2010, 09:26:54 PM
woopy
Thank's Slayer
will try it with more turns on L2
very good video ,  if i understand well you simply connect your main L1 coil to the ground of your garage (house) ? And the distance of power transmission increase strongly  and it seems to be tha  wowww!
woopy
Quote from: woopy on March 31, 2010, 06:30:00 PM
Thank's Slayer
very good video ,  if i understand well you simply connect your main L1 coil to the ground of your garage (house) ? And the distance of power transmission increase strongly  and it seems to be that you can get the power from everything which is connected to the same ground    wowww!
Did you test it in another room of your house with the same ground connection ?
regards
Laurent
slayer007
Thank's A
very good video ,  if i understand well you simply connect your main L1 A to the ground of your garage (house) ? And the distance of power transmission increase strongly  and it seems to be tha  wowww!
Yes, It's connected to a small copper pipe just outside my garage.
I also added a 1m pot along with the 1k resistor for finer tunning.
slayer007
Jeanna's Power Plant running the Exiter.
It puts out around 1.6v @ 1 to 2 mA.
It's enought to run the exiter right off the Earth Battery.
I didn't water it yet the ground was still a little damp.It's just durt dug from my backyard.
Here is a video of it.
http://www.youtube.com/watch?v=KF9WUU6fLnU
EDIT. I added a wireless tower by the exiter it puts out around 15.5v from the AV plug on the second tower.
woopy
Hi Slayer
I decided today to try your idea to increase the number of turns on L2. But as i am totally undisciplined i finally made a bifilar Tesla pancake coil.  With o.4 mm copper wire.  The DC resistance is 1.2 ohm and the inductance -0.023 mh  (notice the minus and i try all set up on my inductance meter). ?
Than i try to trigger my main coil with this config and got no results  no resonance.
So i reinstalled my original single  pancake coil  and i put the Tesla pancake on the top of the coil as a pickup coil.
And here the scope trace  ( probe on one single lead of the coil)    very nice AC trace of pick to pick 100 volts on a 1.2 volts battery.
So with this new coil i did  not resolve the heating of the Transistor (i blew another one this morning with some other test)  but i got a new intersting result .
We are not ready to go sleeping with this technology. Every day a new discovery . Fascinating !
good night
Laurent
