6 volts DC in 130 volts AC out simple generator
Started by magnetman12003, April 01, 2010, 04:41:06 PM
magnetman12003
Thanks for all your advice guys. I like that north /south- east west coil wiring idea  I will have to try all those ideas out. In the meantime I posted another video where I am measuring in and out voltage/current of this generator device. The  horizontal position I have the flux pickup coil in is not the greatest but it but it kept trying to roll of my work table in a vertical position when I made the video. I get higher results in the vertical position. I have my own power figures but am not making any claims that would embarrass me later. I know better than to do that.  What do you figure as in and out power from what you see?
Tom
e2matrix
Hi Tom,  I'm guessing about 0.12 watts (6 volts x 20 milliamps) in and if you are even getting 1 milliamp out then it sounds like you have OU.  I'm guessing you are getting more than that but then I'm an optimist  ;D
    Best of luck with the motor and please keep us updated.
Bruce_TPU
Quote from: magnetman12003 on April 19, 2010, 09:34:17 AM
Tom
Hi Tom,
I wrote on your other thread.  You must rectify and then measure.  It really is the only way.
Glad that you liked my second coil idea.  It will work.   ;)
Also, any chance of upgrading to a N52 magnet of the exact size?
Thanks!
Bruce
magnetman12003
z.monkey
Howdy magnetman12003,
I shop at KJ Magnetics also.  Got some N52s for my latest MCPT (Magnetized Composite Planar Transformer).  I had been toying with the idea of using the big diameterically magnetized rings on axles on both sides of a solenoid like coil.  I would probably have to draw this for you.  Visualize two magnets like you are using on two axles connected with a timing chain so that they spin at equal speeds.  These two rings are on opposite sides of the coil.  When they are lined up they are attracting.  This way we double the lines of force through the center of the coil.  Then, say make one of the axles stick out from the coil arrangement and mount a propeller on it.  Add a tail on the back side, and stick it up in the wind to see if you can generate some power...
About measuring power, you don't have to rectify the voltage to measure it.  Just put a load on there and measure the alternating current and voltage.  Its still power, just in VAs rather than watts...
N52s Rock!
Goodwill to All, for All is One!
