Gain kinetic energy without changing the potetial energy in advace.
Started by Low-Q, April 11, 2010, 02:41:13 PM
Low-Q
Maybe the subject is misleading, but I have tried different approaches to generators that does not need input energy to generate power out.
Here in this thread I want to display an idea that might seem like the obvious solution, but I do not have knowledge to say if this claims below is true or not. So please come with inputs and comments.
If you have a wheel with many containers filled with air - looks like a ferris wheel (See picture below). If this wheel is under weater, the water will provide more pressure at the bottom than the top. This will force the air inside the containers to compress more at the bottom than the top, so the volume will shrink as the container goes deeper and deeper. It is obvius that work has been carried out on one side from the top to the bottom. On the other hand, the opposite work has been carried out on the other side, so no net energy has been carried out. That means it takes no extended energy to rotate the wheel except fighting against the water - the wheel can be designed to easily rotate in water, so we do not take this loss into account.
The containers can be modified to have a flexible membrane on one side so the volume can change easily. This means that the membrane will move in and out for every revolution of the wheel. We still do not apply energy to rotate the wheel.
So then we attach a dynamo on each membrane so the dynamo can run and generate electricity as the membrane push and pulls a magnet through a coil - the dynamo.
Even if we load the coils with a light bulb, the membrane will still move in and out to pull the magnet through the coils as the wheel rotate - and we still do not apply energy to rotate the wheel. Or do we????
I have thought that if we take energy out of all coils at the same time, which we must, I believe the voltage must be rectified first so the energy doesnt cancels out due to the +30 degree phase shift between each next coil in this case. Left side versus right side will without being rectified be 180 degrees delayed which means energy cancellation.
So what happens when we load all the coils?
First, the membranes will not move as much, but they will still move due to the pressure difference. The energy we can take out is the difference in force the water does on the membranes at the top and the bottom, times the distance the membranes are traveling in and out.
Say we have 12 membranes as in the picture. Each membrane are 10cm^2 and they travel 10cm p-p. The wheel is 1m in diameter.
The energy for one membrane to produce per revolution:
100N x 0,1m/2 x 0,7071 = 3,53J
Energy for all 12 is therfor 3,53J x 12 = 42,4J or 42,4Ws
Then we have to convert this energy into electric energy. We have loss as resistance in the coils. In fact we can short circuit the coils and generate heat without doing any extra work on the wheel!!
How absurd does that sound - heating up water without energy input? But it still seems so obvious it can work this way. Because the wheel would spin just as easy with or without change in the membrane excursion - under no load!
Any comments are welcome. I cannot see the reason why this wheel isn't OU. Can you?
Low-Q
BTW: The coils do not move back and forth, but only follow the rotation.
Vidar
brian334
Nice Drawing,
What makes the tanks get lighter at the bottom
and heavier at the top?
It look like at the top the tanks are to lite to sink,
and at the bottom the tanks are to heavy to float-up.
Low-Q
Quote from: brian334 on April 11, 2010, 04:11:14 PM
Nice Drawing,
It is just a simple drawing that shows that the tanks volume at the bottom is less then on the top. This wheel is not suppose to rotate due to unbalanced wheel principle, but rather see the posibilities to use gravity and water pressure to run small generators that is powered by the membranes that must go in or out of the volume behind it in order to power magnet rods inside a coil. The mass is the same in all tanks, but the volume of air inside them are different due to the movement of the membranes that is pressed in by the water pressure at the bottom, and released at the water surface.
I simply couldn't draw all positions of the membrane, so I took a short cut in the drawing - just to be misunderstood as the result ;D.
Hope you have got the idea on how it is suppose to work now :)
Vidar
Cherryman
Hi,
I think it has possibilities, i draw a concept of  something a little similar a while back ago.
This one turns a wheel with water inside, uses the buoyancy, the magnets will float/sink along linear pick up coils
The animation is not perfect it misses a few frames, but you get the idea.
http://i48.tinypic.com/2ppg46w.gif
http://i45.tinypic.com/33m4qrn.jpg
The idea behind it is, i think it takes less energy to turn a wheel, with a liquid and floating/sinkink parts INSIDE it compared to the energy provided by the object inside the liquid because of gravity an buoyancy will try to float or sink.
