Here's your free energy
Started by Dave45, April 12, 2010, 07:56:12 PM
onthecuttingedge2005
I would like to see water the other way around, under about 1 million Earth Atmospheres.  8)
Dave45
I dont believe it will melt, it may to a certain extent but as long as the vacuum is held it will still stay ice.
If you have tried it, I sure would like to see a vid. I will be checking it out as soon as I get the right compressor. The possibility's for this are endless ice chests that dont need ice refrigerators that dont need electricity air conditioners that only use a fan.
Now that the idea has been posted on a public forum it should be free right, no patents. The way it should be, minus the greed.
Cherryman
Quote from: onthecuttingedge2005 on April 13, 2010, 01:10:17 AM
FirePiston - Generating High Temperature by Compressing Air in a Cylinder
The FirePiston glowingly demonstrates the rise in temperature when a fixed mass of gas is compressed. A piece of tinder (a bit of toilet tissue will do) inside a hollow transparent cylinder ignites when the contained air is compressed by a hand operated piston. This is the same process that ignites the fuel inside diesel engines � properly called compression-ignition engines. Includes various tinders with instructions on how to use them for good effects.
http://www.newenergyshop.com/htm.Human.Power/Human.Power.all_en.htm
