One ring to control them all
Started by Cherryman, April 13, 2010, 07:29:33 AM
Cherryman
The "bullet" will travel very fast. It will not only be shot away, but also rotating around its own axle.
This you can influence by controlling the weight and schape of the bullet.
The simplest projectile will be a round ball, if you want you're own magnet set-up you can put the ones you like inside the ball
This will make it easy to experiment with different magnet and coil setups.
DreamThinkBuild
Hi Cherryman,
Very cool design, almost there with a non destructive flux compression generator. A magnet though could get demagnetized by the heat of the explosion.
Another idea that wouldn't use explosives would be a high speed motor setup like a "baseball pitching machine". Use a large center rubber wheel for a flywheel effect and smaller satellite wheel for putting a spin on a 2" magnetic sphere. A clear plastic tube with pickup coils wrapped around which would be rectified for usable power. The only time the motor would be under load is when the sphere comes around for another kick. In effect decouple the magnet from the wheel.
Cherryman
Quote from: DreamThinkBuild link=topic=9048.msg237448#msg237448 =1271174320
Hi Cherryman,
Another idea that wouldn't use explosives would be a  motor setup like a "". Use a large center rubber wheel for a flywheel effect and smaller satellite wheel for putting a spin on a 2" magnetic sphere. A clear plastic tube with pickup coils wrapped around which would be rectified for usable power. The only time the motor would be under load is when the sphere comes around for another kick. In effect decouple the magnet from the wheel.
Tnx.
The magnets could be heat shielded.  Or the combustion could be neutralized to an air movement without heat.
Cherryman
Update:
- Tested small explosions in a tube
With a mobile phone charcher  and some kitchen stuff i tried if i could make an explosion.
That works.
Now i got some materials.
