GENERATOR- YOU DO THE IN/OUT POWER MATH
Started by magnetman12003, April 19, 2010, 09:16:15 AM
gyulasun
Do you have a 10kOhm or 4.7kOhm potmeter? it would be good too.
If you use the 100 Ohm only the base current into the transistor would be extremely high and this would load the 555 output stage way too much too.
Maybe you could replace the duty cycle potmeter with any value up to 10-15kOhm and use the potmeter ?
Gyula
DeepCut
Great idea !
I have a 10k res so ill put that in place of the 10k fine-control pot and use the pot at the output.
Thanks again :)
DeepCut
Ooops !
One more thing ...
Using a pot instead of a resistor from pin-3, pin-3 would go to an outer leg of the pot or the middle ?
I am thinking the outer leg ?
Gary.
gyulasun
It is all the same: if it goes to an outer leg then the wiper goes to the base electrode
Or vice versa.
DeepCut
It's working a treat Gyula thank you so much :)
My tachometer arrived today :)
Gary.
