GENERATOR- YOU DO THE IN/OUT POWER MATH
Started by magnetman12003, April 19, 2010, 09:16:15 AM
DeepCut
Doh !
I was using my old resistor, which wasn't right for the higher input i'm using now.
I should be using a 180 ohm resistor according to initial input power, but closest i have is a 220 in my box.
New results :
INPUT : 18 VDC @ 0.105 A = 1.89 W
OUTPUT : 2.8 VDC @ 0.005 A = 0.014 W
It's running fairly slowly but it's running for 15 minutes now.
What do those figures mean to you guys who know the maths ?
Gary.
DeepCut
my best friendes mum dieid we are drunk and away for the weekend
Bruce_TPU
Our condolances, Gary.  Peace to your friend and his family.
Kind regards,
Bruce
DeepCut
mscoffman
The 2channel scope is surprisingly inexpensive, just be aware of the
fact that the sample rate (see specification) is what determans the
max bandwidth signal you can look at and it is really low. There is
frequency aliasing at 2x the sample frequency.  The 5channel scope
is somewhat better in the frequency department. You may want to
observe a Hantek DS-2090 USB Scope for comparison. Any of the
oscilloscope probes listed on that page will work as they all greatly
exceed the signal bandwidth of the unit itself.
:S:MarkSCoffman
