GENERATOR- YOU DO THE IN/OUT POWER MATH
Started by magnetman12003, April 19, 2010, 09:16:15 AM
DeepCut
Doh !
I didn't have the lead pushed right in when i switched sockets :(
S O R R Y !
Bruce_TPU
Quote from: DeepCut on April 21, 2010, 09:23:50 AM
OK, hope i'm doing this correctly.
Input : 12.56VDC @ 0.130A
Output (rectified) : 33.6VDC @ 0.125A
The output is going through a 10k pot, turned all the way up, in series with the analogue meter.
If i've done this correctly then :
Input : 1.6328W
Output : 4.2W
COP = 2.57
It's RPM is 12,000 !
I've been reading up on generator windings and have some ideas, will post when formulated and tested properly.
Gary.
Easy Deepcut,
Take a deep breath.  Again, you are comparing AC to DC.  This does not work for attempting to measure OU.  I have seen so many fooled by this over the years, I have lost count.  Duty cycle, etc.  Did you watch Tom's video?  Did you notice the LED's blinking?  That means the power is not "on" all of the time.
Solution:  You MUST rectify the AC to DC using High speed switching diodes!  Place a resistor as a load at the out put, and THEN measure amps and volts, using ONLY an analog meter, that will not be fooled by a rotating magnetic field.
I say this to help you.  Also, consider what I wrote about the other coil at 90 degrees.  You guys are wasting space on both side (if vertical) for no reason.
Keep on...  ;)
Bruce
DeepCut
Hi Bruce.
I'm not comparing AC to DC, i am rectifying - see 2nd and 3rd lines of my previous post.
*EDIT* But i know what you mean about duty-cycle, i saw that when i put a load on mine. *EDIT*
My bearings arrived this afternoon so am remounting the whole thing tomorrow, along with the extra coil :)
Reading these was interesting :
http://davidsonsales.com/docs_pdf/CoilPitch.pdf
http://www.bmcoi.com/CatLit/Power/TECHNICAL%20PAPERS/GEN.%20WINDING%20PITCH%20-%20LEKX3115.PDF
Gary.
FatBird
DeepCut
Don't thank me thank google ;+}
They are interesting aren't they ?
Especially in relation to a single-magnet rotor ...
Gary.
