Breakthrough with the Anton HHO cell !
Started by hartiberlin, April 25, 2010, 02:33:30 AM
billmehess
I guess I am not quite getting this, how are they electrolizing the water to produce the HHO gas. Are they using a battery?
hartiberlin
Quote from: billmehess on April 25, 2010, 02:33:16 PM
No,
they just use 3 Anton cells in parallel to produce the HHO gas
and power them with this power supply
you see on the table with the LED display.
This power supply is then powered by the generator output,
of the motor generator, that runs just on HHO / air mix,
so it is a selfrunning system.
So the only thing you have to supply is some water from time to time !
Hope this helps.
Regards, Stefan.
ramset
Stefan,
I imagine this is an Open source project?
Will the particulars be shared here ?[enough to accurately replicate]
Or?
Thanks
Chet
Thanks Grandma
hartiberlin
Yes, it is open source.
:D
I will post now some more pictures from the German overunity.de
site over here with some translation.
Regards, Stefan.
Rapadura
Technically, it's not "overunity" or "perpetual motion", it's "using water as a fuel".
Anyway, it's astonishing!
I hope more tests are done to show that it can run for longer time just on water. And I hope it can run on sea water, because potable water is very scarce in our planet, and can't be used as fuel!
