Breakthrough with the Anton HHO cell !
Started by hartiberlin, April 25, 2010, 02:33:30 AM
ramset
Valentin
Quote:
But it can take some time and we have a very limited budget. I am sorry about that.
Can those of us that wish to, "donate" to your work?
You come highly recommended and your goals of finding an alternate sustainable energy source are what this is all about!
  No reason to waste time because of finance,you are sharing all. I am willing to donate what ever I can afford to
your research
Paypal??
Chet
Thanks Grandma
Omnibus
Hi Valentin,
Thanks for coming to this forum. Very nice work. Wish you all the success. You deserve it.
Can you please explain what the current efficiency was in the video where you were measuring the volume of gas. You might have explained it there but it's in German and couldn't understand what you're saying.
Also, have you done calorimetric measurements of the outcoming gas to see if its enthalpy differs from what's expected? The effect should either be due to a violation of Faraday's law, that is, producing more gram-equivalents of gas than the predicted by the coulombs that have passed through the cell or due to a hitherto undetected higher enthalpy of the obtained gases. This has to be established even prior to getting into the trouble of using it as fuel for a motor-generator. The latter is telling indeed but seems more complicated technically to have the test rigorously done. In a calorimetric test you don't have to rely on cheap Chinese junk and is financially less draining.
Would it be possible to send me a cell to study for a month or two which I'll return to you when finished?
sushimoto
Maybe a little hint to the crackheads on the issue?:
One of the cells was filled with UREA in pevious tests of several electrolytes.
One of the other cells was freshly build and the plates where cleaned with acetone.
For the latest setup, all the cells were filled with a 5% KOH solution.
Is it possible, that some remaining N-molecules combined with
nascend hydrogen to  something else like N2H4 for the extra-bang?
DAMIT DAS MOEGLICHE ENTSTEHT, MUSS IMMER WIEDER DAS UNMOEGLICHE VERSUCHT WERDEN.
ramset
Sushimoto
is this the cell you were working on?[at energetic]
Or do I have you confused with someone else?
[if so my apologies].
Chet
Thanks Grandma
mscoffman
Quote from: Omnibus on April 25, 2010, 08:19:56 PM
I hate to correct people on terminology but I'll say it for the sake of those who might want to use it correctly -- it's non-stoichiometric and not non-stochastic. Stoichiometry is the proportion set in stone between the moles of reactants and the products given by a chemical (electrochemical) reaction. Stoichiometry is an expression of one of the basic laws of Chemistry -- the law of constant proportions and has nothing to do with stochastics -- the area of mathematics which studies random processes and probabilities therefrom.
You are correct I do projects in both areas and my brain was wired for statistics.
