A home's garden hose can provide electricity
Started by keihatsu, April 26, 2010, 06:48:03 PM
innovation_station
a salt water battery and a jt powering my kicker board  will give much more and cost much less ..
lol
or earth battery or solar
if you can afford boost caps you can get massive power out of the unit ..
ist!
sparks
    If we could get the tank on the roof to fill up with rain water that the Sun lifted during the day and deposited in the tank at night then it would be a good idea.  Someone actually holds a patent on creating a permanent location for a cyclonic storm.  The currents passing through turbines on their way towards a permanently maintained low pressure center in  the middle of the turbines.  Possible use for Stonehendge.  The giant red spot is thought to be a permanent hurricane on that planet.  A hurricane is like a giant conveyor belt that uses stored up heat in the ocean to make the air rise where it is cooled becomes more dense and falls back to Earth.  The difference being that momentum builds in the vertical circulation with one side of the wheel having heavy rain falling connected to the other side of the wheel that has warm light vapor rising.  The bottom of the wheel sweeping across the heat scource and the top of the wheel sweeping across the cold scource.  A natural stirling engine.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
Magluvin
Well if running the water to the container on the roof is able to produce energy, then maybe just use the water pressure from the line to run a gen then output to the sprinklers. Get paid to sprinkle on the utilities tab.
Mags
Magluvin
But then again, by running the water to the roof is using more energy to do so along with the water that you are being charged for. So run it to the roof, then run the gen, then store the water for use later, or just sprinkle the lawn. There is energy there for the taking.
Mags
sparks
   Tesla turbine is the way to go.  It will not create a pressure drop like a standard positive displacement turbine.  It works off the flow alone not the pressure differential.  This way your sprinkler heads will still have the same amount of pressure differential.  This is how dumb some people are.  They just built this huge dam in asia.  They displaced umpteen people and interrupted farming and fishing operations for an entire valley so they could build this giant fucking dam when they could have just put some Tesla turbines in the river and everybody could still be doing their thing.   This prooves the electrical concept also that current can do work without dropping voltage.
Think Legacy
Spread the Love
