Thanks to ALL for your help!!
Johann Bessler and the Fibonacci Number Sequence?
Started by Alexioco, April 27, 2010, 06:40:45 AM
AB Hammer
Greetings Alex
In this game it is a lot of guessing and acquired skill by studying reactions and effects. We learn different ways of lifting and shifting. Bessler said something about lifting 4 lbs with 1 lb. PM sent
Alan
Alan
Mk1
@all
The sequence of numbers have been extracted from nature , golden geometry , its the structure of life and reality it self down to its smallest parts . Nature was not familiar with the decimal system  ;).
There is not a correct answer to it yet , but to me it is quantum mechanics .
But i will however try to illustrate we usually see numbers as only preceding or following another , we usually do the same with freq since its usually associated to a number and treated as such , big mistake ...
If you play a musical instrument those frequencies become notes and patterns emerges , Usually divided in 12 segments the 12th being the same note as the first at a higher octave and have the same ring in the harmony . The maths of it is quantum physic lets say step one would be
440 the 12th 880 it you go 12 steps back you have 220 now you also need to you divide the 12 unequal steps , a bunch of fun , i also believe there is a is a hidden numerological code , it should be relevant in any outcome . Now this quantum logic need to be used since its the matrix  .
So steps one(440) is half of step 12(880) the values of the first is also equal to its spread .
All and all a bunch of fun !
Those numbers could be 10 different fraction value , 10 vector.
Any of natures system work perfectly and we must some time mirror the result and process to reveal it beauty , we ca work the same way !
I hope i did not confuse anyone  :)
Mark
Alexioco
What about this:
Say you have an off-pivoted seesaw so that when a 1 once weight is put on the long end, there is on the short end an output force of 2 ounces. Now say that 2 ounce output is fed back to the long end of the seesaw, the long end would output 3 ounces, because it already has a 1 ounce output. Because of that, the long end now has a force of 3 ounces, the short end of the seesaw must of also increased to 5 ounce output of force which would then feed it to the other end creating an output force of 8 ounces (3+5=8). This process would continue according to the Fibbonacci Number Sequence... The forces involved would be enormous and would increase infinitely until destruction...
Alex
The love of God is great and true,
A special thing for Him and you,
A perfect friend, a Father too,
Lift up your hearts for He is true.
AB Hammer
Quote from: Mk1 on May 03, 2010, 11:11:22 PM
@all
Mark
Thanks Mk1
When you mentioned the music your point became clear. Bessler would use music due to his work with pipe organs. As musicians Alex and myself should have a good idea. IMO Alex is a very good musician and well versed in classical approaches. I don't see this clue as the answer, but a clue to the possibility of being on the correct path if your designs meets the criteria of true harmony on how one part works with another.
PS. The only proof will come in the running wheel and since we do not know what Bessler truly did, it would be hard pressed to prove it was Bessler's. But as Bessler's writing as a guide it would confirm his place in history. Assumptions rarely prove as facts.
Alan
Alan
Alexioco
Well I have passed my grade 7 music exam and I am now on grade 8 so I'm getting there :) Music is an art is like and strange enough, a lot of the principles in music including how to practice it in also found in nature...
P.S I'm going to make a piece of music using the Fibbonacci Number Sequence to see what comes out  :P
I'm starting to really think now that this number sequence is part of the answer to perpetual motion, the number is found in nature for a start and the numbers increase in a logical order, pairs of numbers increasing the output...
Alex
