Mehess Motor
Started by billmehess, April 07, 2006, 01:33:35 AM
Dingus Mungus
Quote from: billmehess on November 09, 2006, 10:54:42 PM
Been working straight for the past 5 months, everything is now working will post everything before the end of the month. Finishing up some legal work regarding device.
Time to break our the champagne!!!
Yes I have rewond the clock numerous times!
Without the use of a battery or some other form of energy input?
Can you post a pic of the current device as it is running?
billmehess
I will be posting a video next week showing the complete working unit. There is no electrical input to the system.The moving pendulum from the clock motor moves the permanent magnets in and out of the coils to produce a emf. When I first started I could only produce 2-3 mv per hour. I can now generate about 8 volts per hour. This represents a 4000% increase in performance. The motor is on for only 12 seconds per month (the length of time to rewind the clock) . The motor is run by a 12 volt battary which exhibits a voltage drop of only about 40 mv. I have been able to recharge the battary numerous times because of the large excess of energy I am creating. As a matter of fact it takes only a fraction of the energy to rechare the battary as I am gnerating
in excess of 5000 volts per month.
I think this is it guys!!!
Liberty
Quote from: billmehess on November 10, 2006, 10:50:32 AM
Hi Bill,
To prove it to yourself, take a charged capacitor, and use it to replace the battery with.  Your system should recharge the capacitor to keep the device running.  Just take the battery out of the system completely.
Hope to hear good results.
Liberty
Grumpy
Bill,
You can also wave the magnet past a coil rather than in and out.
Pendulum devices that are OU can be traced back to late 1800's.  Self winding watch uses a pendulum.
9 hits at the European Patent Office - not all relavent:
http://v3.espacenet.com/results?EC=h02k53%2F00&AB=pendulum&DB=EPODOC&sf=a&CY=ep&PGS=10&ST=advanced&LG=en
Do a search for ltseung888 - He's a Chinese engineer that explained the pendulum/gravity effect rather nicely - posted the data on several sites.  This patent appears to be the same thing - use bebelfish to translate:
http://v3.espacenet.com/textdoc?DB=EPODOC&IDX=DE19744326&F=0
Congratulations!  Have you been able to run a load and still charge yet?
        -Frank Edwards
billmehess
Moving the magnetS in an out of the coilS produces a much greater emf than passing it over the coilS. I am using a 12 volt deep cycle battary to run the motor. The uniqueness of this device is that the motor only has to be energized 12 seconds per month to operate the clock pendulum for the entire month. I have a pleantly of juice available from the battary to run external loads and be able to recharge the battary back up to its full capacity.
I have run small dc motors and bulbs and been able to recharge very easily . I will file a provisional patent on Monday 11-13 with updates on the original provisional patent I filed in June of this year.
Next week I will load a video and all data and info of the device.
This motor generates electricity with no electrical input. It is not dependent on any outside source. It is totally a closed system. The device is totally scaleable. I will show that it meets all the requirements of the FIRST REAL
OU system.
