Mehess Motor
Started by billmehess, April 07, 2006, 01:33:35 AM
Dingus Mungus
Quote from: billmehess on November 13, 2006, 09:26:59 AM
This is interesting but I observe the following:
Its really big and massive. Also it needs a constant source of energy (in this case water) running at a constant rate. What if you are running no water at the time, based on this design nothing would happen. Also Not a closed loop system and it requires an external input from a non regulated source. A standard hydroelectic system with running water from a river or dam is an example.Fun to look at though, as always thank you for the input. This is a great community!
My motor will run 24 hours per day. It does not need any external input, it is a totally closed loop system.It can generate its own workable power and store additional. Its OU!!
I wanted to post today but I need to finish up some last minute additions to the unit. I will post tommorow
morning, Tues am. pacific standard time.
Well put, but my point was just like your discribed set up it uses weights to sustain output over 1-28 days depending on how you gear it. The water required to reset it daily or monthly is less then the waste deposited by a household daily. Its just a way of extracting energy from a waste process that already is occuring. I look foward to your results.
billmehess
Ok here it is,
This is the first phase of the design
Web site address is a bit long and must be entered exactly as follows, no www
http://geocities.com/auction606/index.html
Text except for last page is copy is the provisional patent. Any questions feel free to contact me direct.
Bill Mehess
503-366-9135
Oregon USA
The time I am posting this is 12:56 Pacific Standard time
CLaNZeR
Excellent Bill.
Makes you wonder if you could use the same principle regards using the swinging magnets to clear the sticky point on a magnetic spiral wheel as in my experiments I am down to only moving the magnet back a few mm's to get past the sticky point.
You would have to calculate the correct size of the wheel to match the swing and the RPM's would remain the same, but I wonder if the torque of having the wheel would produce more power than exciting the coils.
Fantastic idea though and well done!
Sean.
http://www.overunity.org.uk
Nostradam
Hi Bill, well done.
A few questions:
Why do you charge each capacitor independently ?
Do you then put all in series and dump them across the battery ?
You better could use Shottky diodes, which can conduct better and have not such a high resistance as Germanium diodes.
Also better use alufoil capacitors. Electrolyte capacitors have too many losses.
Do you dump the charge only once per hour into the battery ?
