CMPT
Started by z.monkey, May 19, 2010, 05:23:45 AM
z.monkey
There, once I have both in place then I can wind the Polar Coil...
Goodwill to All, for All is One!
z.monkey
I wound 40 feet of wire on each side of the polar core, the N52s...
z.monkey
Here it is on the Test Jig, ready to be wired and tested...
z.monkey
So, after doing some testing this coil is different to say the least.  It doesn't do anything at low (60 Hz) frequencies.  I need to do a lot more testing, and don't have the time right now.  I had to sweep the frequency up to the limit of my sine wave generator to get it to respond a little.  The input voltage to the Polar Coil is a ~3 Volt sine wave at around 5 KHz.  The output voltage is ~15 Volts AC, but there is almost no current.  I have a 10 Watt bulb on the test jig which doesn't light...
So the initial idea for this Composite Magnetized Planar Transformer (CMPT) was to take a dense magnetic field and modulate it to shake some electrons loose using accretion.  I think there needs to be a lot more testing done here, both in the field of planar transformers and also modulating dense magnet fields.  So, I positively can not say that this is finished, and also cannot call it a success, or a failure.  I guess its another Work In Progress, got a few of those stacked up...
