Dia. Mag. Alternator
Started by z.monkey, May 27, 2010, 07:34:19 AM
z.monkey
Quote from: webby1 on September 09, 2011, 01:28:05 PM
looking good z.monkey, soon the fun shall continue hopefully with no more aluminum shower ;)
Thanks Webby,
Would you like some fresh grated aluminum with your test?
Goodwill to All, for All is One!
Hope
Your Mag Alternator is a work of art Z!   Nice job.
This is how the out come of the energetic forum bifilar coil works, it is finally working out and making production beyond the input.  You will see in an instant how to adapt the concept to your projects so I am including it here for all.
z.monkey
Thanks Hope, I think I hooked up DiaMag6 that way.
http://www.overunity.com/index.php?topic=9220.msg264813#msg264813
Working on the platform now.  I'm making some tongue in groove right angle
brackets to hold the motor/alternator plate, and the platform base together.
http://scientilosopher.blogspot.com/2011/09/scrap-bar-clamps.html
z.monkey
Been clearing space, deconstructing old stuff scavenging what I need to
build the new stuff.  Got the groove cut in the piece of 1.25 inch square
pine to be the meat of the right angle brackets.  Then made some triangles
with 3/8" plywood...
http://scientilosopher.blogspot.com/2011/09/groovy-brackets.html
z.monkey
Building the pedestal for the test plate.  I mitered some
square pine stock for a frame.  Then glued and screwed
the pedestal base together.  Cleaned up the groovy
brackets, and glued them together.  Then test fit the
motor/alternator plate.  Looks good so far...
