Working Air Battery
Started by lasersaber, June 08, 2010, 11:39:33 AM
rock321
Hello Everyone,
By the Grace of God the Father and the gifts He's given through His Son Jesus Christ, I'd like to share some of the data from experiments done with versions of this type of battery.
I've had one of these type of batteries running a super bright LED of 28,500 mcd and 3.5-4.0 volts for 6 weeks continuous. The decay rate of the ribbon seems to be on the order of about 1000 hours. Then you can use the remains for hydrogen generation. Each one of these mini batteries that powered the LED produced from 3-3.5 volts. Run in series they produced about 5.5-6 volts.
I did not need a JT or any other type of electrolyte other than tap water. The higher voltage is acheived very simply and further experimentation should get 6-7 volts out of only one tiny unit (1 inch by 1/8 inch).
Hope this data is helpful. I'll be posting on Youtube probably (God Willing) tonight.
Blessings,
LittleChristgod
jeanna
Hi everybody,
I just got back from 3 nights in the camper.  :D
the first thing I noticed was that the mag ribbon that I left in the salt water is broken into 2 pieces, and the same length of ribbon in the MgSO4 solution is fine.
There were few bubbles on either ribbon when I first touched them, but now after the 'agitation' is stopped, they are both producing many bubbles again.
Just before I left, I bought a 3 foot piece of 1" copper pipe from the hardware store.
It was a bit longer than 3 ft and I ended up with 5, 7" long pieces and 1, 3" piece.
I made 2 batteries; one, with the 3" and one with the 7 inch long piece. (and 4 left unwrapped.)
I took a pic of all the ones I have so far with the 4 bare copper tubes of potential batteries.
The 3 inch battery is lighting the JTC with 2 leds in parallel on the secondary. It can light more in parallel, I just took this pic.
In the pic you can see the 3 inch one right in front of the very tall one from last week.
This I did because I have in mind to cut that very long one a little shorter to make 7 inches and a 3 inch piece for another short one.
While these lights are bright they are not bright enough to light up one of those globe lamps. (Like the tiny toroid world light.)
I want to make them as bright as that, because that is a long lasting useful lamp.
One more thing to mention is that in about 50% humidity, these are drying out in about 3 hours.
It will be very interesting to see if they outlast the ones covered with tape.
Oxidation vs being "on" for longer.
If the Air battery thing is really true (the korean sea water battery uses only mag and air in sea water)  then while the electrode ends seem off then energy is leaking out somewhere.)
The pic shows from L-R
The nearly useless carbon rod wound with Mg ribbon in the green glass. (I think this is the wrong kind of carbon rod, or something happened to break the magnesium ribbon apart under the tape.)
The 1/2" pipe which is wound with tape over the magnesium,
The really long one,
the 3 inch which is lighting the 2 leds,
Then the 7 inch and
4 more unfinished copper tubes.
I like the copper because it is about $4.40 for a foot long piece of 1" pipe, and the 7" length is $2.60. I think this is very affordable.
Now to make it a strong producer!  ;)
Here is the pic.
I think the most interesting thing today is that the mag ribbon in the table salt was broken after 3 days and in mag sulphate was fine.
I hope this is not too confusing!
jeanna
jeanna
Here is what I should really be showing you.
In the one I am showing the broken pieces of magnesium after 5 days in NaCl.
The copper wire in the same bath looks great.
The second pic is the mag wire after 5 days in the MgSO4 solution and its copper electrode also looking good. (and the others, the NaCl electrodes are in the background.)
jeanna
tishatang
Hi all
I just discovered this link about high voltage (electrostatic) air batteries made 100 years ago!
http://amasci.com/emotor/duluc.html
"Duluc/Zamboni Electrostatic Pile
The DuLuc Dry Pile
High-voltage source
©1996 William J. Beaty
The Duluc Dry-Pile (also called the Zamboni Pile) was an "electrostatic battery" permanent power supply used in the early 1800s and constructed from silver foil, zinc foil, and paper. Foil disks of 2cm dia. were stacked up several thousand thick and then either compressed in a glass tube with endcaps and a screw assembly, or stacked between three glass rods with wooden endplates. Of course this is simply a Voltaic Pile, a multi-cell electrochemical battery, albiet one with output potential in the range of kilovolts. Each cell used nearly-dry paper as electrolyte, with zinc foil for one electrode and silver foil as the other."
This was used a source of power for "Perpetual Motion Machine" also described on above link.  Maybe modern materials can improve on this idea for low voltage applications?
tishatang
stephenafreter
