Working Air Battery
Started by lasersaber, June 08, 2010, 11:39:33 AM
Bizzy
Quote from: Pirate88179 on February 20, 2011, 09:14:35 AM
Nice work.  Have you tired hooking it to a JT circuit?  With 5 volts I think you could light like 500 leds maybe.
Bill
Hi Bill
Thanks... Yes I just did and got 13.98 volts. I have to do some running around this afternoon and am going to pick up a string of LEDs from Lowes to see how well they do. My wife is already making plans for me to hook up LEd lasndscaping liughts for her run only by these batteries.
Bizzy
guruji
Hi Bizzy very nice work keep going. How much voltage and amperage per rod? If there is little amperage to JT try Stingo it runs with 20ma only and even less. Do you have a diagram how exactly done? Regarding Gravity wheel I have posted another idea should see.
Thanks.
Bizzy
Quote from: guruji on February 20, 2011, 03:02:58 PM
Thanks.
Good Morning gruji
When I get to work I will post a diagram. The cells are very easy to make. Although I do admit I had to have my wife help with some of the tape :)
What is a Stingo?
I Looked at your other idea as well. Where exactly does the belt drive run?
Bizzy
guruji
Quote from: Bizzy on February 21, 2011, 06:12:33 AM
Good Morning gruji
What is a Stingo?
Bizzy
Hi Bizzy Good Morning too you too. A Stingo is a small circuit by Sucahyo  if you cannot find it on this forum I will post the diagram. It's like a Joule thief but a bit different with only one winding to the toroid. I found it ; that it charges big batteries quite well with only little amperage.
Regarding the gravity wheel that I planned is a wheel with small wheels around and a weight on their side for unbalance. To hold them on same position while turning; belts are necessary to the fixed centre.
I think this will work and when I have time I will do this. If you did not understood ask me I will help.
Bizzy
Good Morning gruji
What is a Stingo?
Bizzy
Hi guruji
yes if you could post the schematic for the stingo that would be a big help.
I should have the diagram up for the cells later today.
Bizzy
