Magnet Motor from Argentina, part2
Started by hartiberlin, April 12, 2006, 10:41:37 PM
kukulcangod
Luis:
     Felicitaciones y gracias por ofrecer su ayuda y la del senor Torbay
Como es posible obtener 2.5 kilowats de este motor?
Es decir de que tamano deberia ser , o potencia magnetica ?
Cuantas revoluciones por minuto se pueden esperar maximo de este tipo de motor?.
Les deseo lo mejor. Diego
Luis: Congratulations and thanks to offer your aid and the one of Mr.Torbay.
out pf this motor how is it possible to obtain 2.5 watts?
Say what size it should be or magnetic power?
How many rpm can be expected at the most, out of this type of  motor?.
I wish you the best .Diego
handysg
All you trying with the prototype, model or whatever, I think there's something very important missing from the patent that we might have overlook. We would need to add in a heavy flywheel. Just my view, may be wrong.
madmaxx
You only need a couter balance for the rotor magnet. This is not like an overbalanced wheel. At this point I think the builders here are just just trying to replicate with simple prototypes. Mine is made from PVC and other junk from my scrap boxes. As long as it has enough tourque to lift the stator with the ramp, it will continue rotation. If one can achieve this then you can place an induction coil above the rotor to generate electric. From that point we refine and improve to build more effecient and higher power systems.
Been there done that, wouldn't do it again, if only I could remember what I did.
Job - I make signs and custom graphics
madmaxx
No sucess. Not enough torque to lift stator. Here's photo. Ideas?
Will rotate when one is lifted by hand. The rotation will not lift the next stator. The stator to be lifted is attracting and this force cancels out the next pull and the previous push.
Jdo300
Hi Madmaxx,
Which way are the stator and rotor magnets polarized? If those are just standard ceramics that are magnetized through the thickness, then it will definately not work the way you have it. Those magnets need to be magnetized through the length so that the north pole faces the rotor directly. Otherwise the field will not be dense enough to give you the needed torque.
God Bless,
Jason O
