Magnet Motor from Argentina, part2
Started by hartiberlin, April 12, 2006, 10:41:37 PM
hartiberlin
Hi All,
I am having again some problems with the forum software,
so that it does not display this topic from the beginning.
If you for instance go to:
http://www.overunity.com/index.php/topic,933.0.html
it will not display the page...
I have already tried to clean and clear the database,
but in this moment I don?t know, what is going on.
Please let me know, if you can access this upper URL page.
Maybe the SQL database has some problems.
I am looking now for a fix...
hartiberlin
I found the error, it seems the forum software does not like
to enable the picture resizing, so all posts must now
be enabled with the original resolution picture size shown
and not with a thumbnail !
This seems to be still a bug of the forum software.
Okay, I have now again enabled fullsize picture under the posting,
so the page needs to load longer, but will instantly show the big pictures.
Thus I have reduced the postings per page to 5 postings, so the page does
not load too long.
Regards, Stefan. (moderator)
Light
"Please tell us , how your argent.jpg reacte and behaves !".
- Have not much to say yet, so far nothing special, this is just a first step to see the picture of forces. Everything works like Tao says - he's got the concept right, but obviously, there's no '0' forces so far. I believe there's something else inside to make commutation right. I'll post progress and changes.
Yes, Tao, they are too far of each others, did it purposely to see interaction. Do you think needda metal core to amplify the gap, make movement smooth?
jaybird
Wowsers...hello again everyone, I'm back from my week away working...what a thread(s) this turned out to be, and a lot of surprises!
I am still catching up on the thread, but Torbays patent looks just like I thought , and strikingly similar to my details, so I have a prototype very close...hope to do a few modifications Saturday.
Will be on the forums a while catching up...does anyone have a close prototype yet?
JayBird
nsbanzai9
Hello, first post here, and I would like to thank you guys for the play/work being done - I especially appreciated the patent pdf with dimensions!
I have some 12800 gauss NdFeB magnets (could not find larger) that I will be using for a planned prototype.
I wanted to add my enthusiasm and gratitude (see above) and I also wanted to add a fact/factor for your consideration.
I have worked with large magnetic fields (a magnetic resonance imaging machine) and I have experienced the paramagnetic properties of aluminum.  While magnetic materials will be attracted to the field, bouncing and causing great damage, a paramagnetic material, like aluminum, is not attracted (well slightly) but it does focus/gather/conduct the magnetic field.  So if you take a sheet of aluminum and try and move it (perpendicular to the lines of force) through a strong magnetic field you will encounter resistance.  I assume this is a variable you might consider in simulation of the vectors and accurate replication?
