aluminum can and copper wire batterys
Started by old man, June 24, 2010, 04:33:10 PM
old man
all
started new test with two cans
white vinegar and water
vdc       ma
.635      .269
bleach water
1.027      .273
lemon juice water
1.116    .141
The Observer
could you let use no what your getting with your setup if you could ples thank you
tom
The Observer
Old Man,
So far I've deduced that a Steel-Aluminum set up in Tap water Produces .700 to .800 Volts.
(about the same with Steel-Copper  .6 V - .7V)
I came up with the idea last night of using Soup Cans (FE) and Aluminum Cans (AL) for making water batteries for cheap/ free.
Line up 150 of these.. and you would have over 100 Volts...
1500, and you would have over 1000 V.
I would spend a week making these things if it meant I could tell the Electric Company to go take a hike !
The Observer
P.S. Could make 14 V packs that hook up in parallel with a Car Batteries.
        The Car Battery would store excess energy and be available for times of Peak Usage.
old man
I would spend a week making these things if it meant I could tell the A to go take a hike !
now that wood be nice   me all i wont to do is get my bill down so i am starting small if i can find a way off getting these to work and give me 12 v all the time for 5 or 6 moths i can work with that and then i can add to it like moter or run a wind mill to in to a batt bbank  and use things we have at home like me in my test iam useing old house copper wire  that was given to me i can get tvs @vcrs@all kinds of things to use  and i like you idea of useing Soup Cans  and Aluminum Cans  and lee useing empty plastic soda or water bottles idea i thank i can come up with something there  ??? and if you no anybody one here the more heads there is the better ;D and thank you for your help on this
tom
The Observer
Something like this for my Free Materials Setup of the Water Battery. ;o)
The Observer
old man
hey that just mite work i found out what a aluminum cans are made of this will help to no
beverage cans consists mostly of aluminum, but it contains small amounts of other metals as well. These are typically 1% magnesium, 1% manganese, 0.4% iron, 0.2% silicon, and 0.15% copper.
i like youe setup
