New Steven Mark video released April 2006 !
Started by hartiberlin, April 14, 2006, 12:18:43 AM
You can often get the same effect with the use of other elements,quantity depending !
The published phaenomen is like a "superconductor",and I as also the worldwide
scientists are theretime in search of a "superconductivity"-matrix !
S
dL
p.s.:If iron as coil would be so important,this invention is in a really low level:
Marcel Meredieux,FR, invented an induction amplifier without magnets !
Liberty
This is a similar device that must operate in a similar fashion.  Take a look at it, perhaps it will help?
Liberty
Liberty
Quote from: Liberty on April 24, 2006, 11:05:45 PM
After looking at the pdf file of the aerial generator, notice the iron wire is coiled around the horseshoe magnets...  It is also uninsulated wire.  Could this be the type of coil arrangement used in Steven Marks device???  The very important relationship of the coils?  Maybe he is still using that bailing wire!
Liberty
A first question:when the Dragan Kovac,WO2004100349,invention is true-
what is the value of all"overunity-demonstrations"?!
"The invention relates to an infinite utilization of energy,achieved by the series connection of single resistors(for example lamps/bulbs).
Mr.Mannix also describes the use of "seriell connection" !
Kovac seriell connection invention:as example"Ten bulbs a 200W consumes:58W",
so 10 bulbs a 100w will consume:???
Second question/statement:Professor Kanarev describes the use of measuring tools,like oszilloscope/oszillograph and multimeter,different results but both right !
Paradox,yeah!
Sincerely
           de Lanca
Razor
This device is no what apears to be. It's a S.E.A.R.L. disc Inside. I have one and works, like a generator. It vibrate because of cilindrical rotation magnets inside. It produces DC voltage high amperage current. I have to turn it off when no current is draw from it, the start to demonstrate some acomulative effects of ether energy.
